On the blynk help center is a set of instructions to install Node.js on linux. I used the automatic set of commands and it appears that everything installed correctly. However when checking for versions installed the npm -v produced command not found.
Scrolling back into the installation messages I see this notice came up:
Suggested packages:
npm
Do I need to start over and try the manual process or can I add npm seperately?
