Installation/Deployment of Private Blynk Server on a web host
Hello Blynkers,
I was wondering if I can deploy the Private Blynk server on a web host. I just need that to manage the firmware update of a connected microcontroller (STM32F4) over internet.
Thank you!
you sure can.
The instructions are pretty good for the server install.
https://github.com/blynkkk/blynk-server
and here are some sample server.propertes - mail.properties files.
As you are setting it up, some things that catch people are the certs and the ports to connect to. Every now and then mail setup is an issue, but usually solved by re-reading the mail setup section.
Good luck and let us know how you are doing.
Thank you guys! I will give it a try and let you know how it goes!
