Hello, thank you for your awesome app! I love it
the project I’m working on is getting data from pins and logging the using (insert into) in mySQL
this is a draft code because I’m using temp as a placeholder for what I want
I get this error
Exception (3):
epc1=0x402064c2 epc2=0x00000000 epc3=0x00000000 excvaddr=0x40232a24 depc=0x00000000
I have commented the execute out because I just want to see the value for now, but I want that to work too
#include <DHT.h>
#include <MySQL_Connection.h>
#include <MySQL_Cursor.h>
#include <Adafruit_Sensor.h>
#define sensorPin1 0
char auth[] = "auth";
char ssid[] = "ssis";
char pass[] = "pass";
#define DHTPIN 2 // What digital pin we're connected to
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
WiFiClient client;
MySQL_Connection conn((Client *)&client);
char INSERT_SQL[] = "INSERT INTO officeto_plants.TBL_READINGS(ID_PLANT, AIR_HUMIDITY, AIR_TEMPERATURE, SOIL_MOISTURE_1) VALUES (1, NULL, NULL, %d)";
//char INSERT_SQL[] = "INSERT INTO officeto_plants.TBL_READINGS(ID_PLANT, AIR_HUMIDITY, AIR_TEMPERATURE, SOIL_MOISTURE_1, SOIL_MOISTURE_2) VALUES (1, NULL, NULL, %d, %d)";
char query[128];
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
//delay(10000); //10 sec
sprintf(query, INSERT_SQL, t);
Serial.println(query);
MySQL_Cursor *cur_mem = new MySQL_Cursor(&conn);
// cur_mem->execute(query);
// delete cur_mem;
pinMode(sensorPin1, INPUT);
dht.begin();
Thank you for your help!
