Incorrect ADC values while using blynk
Hi guys , I’m working in a project about a Solar panel monitoring system with 3 sensors for measuring Voltage,current,temperature using ESP32 and arduino IDE . Without using blynk , I got a correct values in oled display . but when i used blynk , i didn’t get correct values in voltage and current (oLed display + App).
I think that , the wifi is the problem . because the values are not correct in oled display and App !!!
For the 3 sensors , ADC pins are : 33,34,35
thanks for the help !
Here my code
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include "Wire.h"
#include <OneWire.h>
#include "Wire.h"
#define BLYNK_TEMPLATE_ID "Removed"
#define BLYNK_DEVICE_NAME "Removed"
#define BLYNK_FIRMWARE_VERSION        "0.1.0"
//#define BLYNK_DEBUG
#define APP_DEBUG
#include "BlynkEdgent.h"
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define INPUT_VOLTAGE_SENSE_PIN 34
#define INPUT_CURRENT_SENSE_PIN 35
#define TEMP_SENSE_PIN 33
#define VOLTAGE_SCALE 20.6078431372  // R1+R2 / R2 // (  +  ) /
#define CURRENT_SCALE 2 // R3+R4 / R4// ( +  ) /
double mVperAmp = 0.066; //Sensityvit of the sensor //  use 100 for 20A Module and 66 for 30A Module
double ACSoffset = 2; // Ideally it should be ( 0.5 x Vcc )
unsigned long last_time =0;
unsigned long current_time =0;
float power =0 ; // Power in Watt
float energy =0 ; // Emergy in Watt-Hour
float tempC=0; // temperaure in Celcius
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
OneWire oneWire(TEMP_SENSE_PIN);
  delay(100);
  BlynkEdgent.begin();
  if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
    Serial.println(F("SSD1306 allocation failed"));
    for (;;);
  display.clearDisplay();
  display.setTextColor(WHITE);
  display.display();
  delay(500);
    // read voltage and current
  float voltage = abs( return_voltage_value(INPUT_VOLTAGE_SENSE_PIN)) ;
  float current = abs( return_current_value(INPUT_CURRENT_SENSE_PIN)) ;
 // read temperature from DS18B20
  sensors.requestTemperatures(); // get temperatures
  tempC = sensors.getTempCByIndex(0);
  //tempF = sensors.getTempFByIndex(0);
  // Calculate power and energy
  power = current * voltage ; // calculate power in Watt
  last_time = current_time;
  current_time = millis();
  energy = energy +  power *(( current_time -last_time) /3600000.0) ; // calculate power in Watt-Hour // 1 Hour = 60mins x 60 Secs x 1000 Milli Secs
  // ================= Display Data on Serial Monitor ================================================
  Serial.print("Voltage: ");
  Serial.println(voltage);
  Serial.print("Current: ");
  Serial.println(current);
  Serial.print("Power: ");
  Serial.println(power);
  Serial.print("Energy: ");
  Serial.println(energy);
  Serial.print("Temp: ");
  Serial.println(tempC);
// ================= Display Data on OLED Display ================================================
  // Display Solar Panel Voltage
  display.setTextSize(1);
  display.setCursor(10, 5);
  display.print(voltage,2);
  display.print(" V");
  // Display Solar Panel Current
  display.setCursor(90, 5);
  display.print(current,1);
  display.print(" A");
 // Display Solar Panel Power in Watt
  display.setTextSize(2);
  display.setCursor(25,30);
  display.print(power);
  display.print(" W");
 // Display Energy Generated by the Solar Panel
  display.setCursor(25,50);
  if ( energy >= 1000 )
   display.print(energy/1000,2);
   display.print(" kWh");
  display.print(energy,2);
  display.print(" Wh");
  // Display Temperature
  display.setCursor(35,18);
  display.print(tempC);
  display.print((char)247);
  display.println("C");
  display.display();
  BlynkEdgent.run();
  Blynk.virtualWrite(V0, voltage ); // virtual pin 0
  Blynk.virtualWrite(V1, current ); // virtual pin 1
  Blynk.virtualWrite(V2, power ); // virtual pin 2
  Blynk.virtualWrite(V3, energy ); // virtual pin 3
  Blynk.virtualWrite(V4, tempC  ); // virtual pin 4
//========================= Function to Calculate Solar Panel Voltage ===================================
double return_voltage_value(int pin_no)
  double tmp = 0;
  double ADCVoltage = 0;
  double inputVoltage = 0;
  double avg = 0;
  for (int i = 0; i < 100; i++)
    tmp = tmp + analogRead(pin_no);
  avg = tmp / 100;
  ADCVoltage = ((avg * 3.3) / (4095)) +0.19
  ; // 0.184 is offset adjust by heat and try
  inputVoltage = ADCVoltage * VOLTAGE_SCALE;
  return inputVoltage;
//========================= Function to Calculate Solar Panel Current ===================================
double return_current_value(int pin_no)
  double tmp = 0;
  double avg = 0;
  double Amps = 0;
  for (int z = 0; z < 150; z++)
  avg = tmp / 150;
  ADCVoltage = ((avg*3.3) / 4095);
  Amps = ((ADCVoltage * CURRENT_SCALE - ACSoffset ) / mVperAmp); // 2 is the scaling for voltage divider
  return Amps;
I’d start by putting these two lines of code where they belong - T the top of your sketch…
Then I’d read this…
https://docs.blynk.io/en/legacy-platform/legacy-articles/keep-your-void-loop-clean
Then I’d restore the board type definition lines of code that you deleted, and un-comment the most appropriate one, and check that there are no pin conflicts in Settings.h as described here…
I’d also check the min/max values that you’ve defined in your datastreams that you’re using.
When you’ve done that, post your revised code, your serial monitor output, and proper details of the values that you’re seeing in the OLED and app.
which current sensor are you using
