In my application V1 pin is automatically blinking in the app and esp32 without touching
created a new project with 8 channel relay with esp 32 board, and software blynk local server with arudino,
code compiled successfully and able to upload successfully but I didn’t the virtual p1 but it is continuously blinking and esp 32 board console log also showing showing v1 is on/off but respective relay doesn’t have any change, its state, only in the v1 pin in blynk app and esp32 console log only toggling
here is the actual code
// define the GPIO connected with Relays and switches
#define RelayPin1 23  //D23
#define RelayPin2 22  //D22
#define RelayPin3 21  //D21
#define RelayPin4 19  //D19
#define RelayPin5 18  //D18
#define RelayPin6 5   //D5
#define RelayPin7 25  //D25
#define RelayPin8 26  //D26
#define SwitchPin1 13  //D13
#define SwitchPin2 12  //D12
#define SwitchPin3 14  //D14
#define SwitchPin4 27  //D27
#define SwitchPin5 33  //D33
#define SwitchPin6 32  //D32
#define SwitchPin7 15  //D15
#define SwitchPin8 4   //D4
#define wifiLed    2   //D2
#define VPIN_BUTTON_1    V1
#define VPIN_BUTTON_2    V2
#define VPIN_BUTTON_3    V3
#define VPIN_BUTTON_4    V4
#define VPIN_BUTTON_5    V5
#define VPIN_BUTTON_6    V6
#define VPIN_BUTTON_7    V7
#define VPIN_BUTTON_8    V8
int toggleState_1 = 1; //Define integer to remember the toggle state for relay 1
int toggleState_2 = 1; //Define integer to remember the toggle state for relay 2
int toggleState_3 = 1; //Define integer to remember the toggle state for relay 3
int toggleState_4 = 1; //Define integer to remember the toggle state for relay 4
int toggleState_5 = 1; //Define integer to remember the toggle state for relay 5
int toggleState_6 = 1; //Define integer to remember the toggle state for relay 6
int toggleState_7 = 1; //Define integer to remember the toggle state for relay 7
int toggleState_8 = 1; //Define integer to remember the toggle state for relay 8
int wifiFlag = 0;
#define AUTH "rF4sdfsfsdfdNRv2XxdEJmGsKXSC-flqUG2I-"                 // You should get Auth Token in the Blynk App.
#define WIFI_SSID "XXXX"             //Enter Wifi Name
#define WIFI_PASS "XXX123"         //Enter wifi Password
void relayOnOff(int relay){
    switch(relay){
      case 1:
             if(toggleState_1 == 1){
              digitalWrite(RelayPin1, LOW); // turn on relay 1
              toggleState_1 = 0;
              Serial.println("Device1 ON");
             else{
              digitalWrite(RelayPin1, HIGH); // turn off relay 1
              toggleState_1 = 1;
              Serial.println("Device1 OFF");
             delay(100);
      break;
      case 2:
             if(toggleState_2 == 1){
              digitalWrite(RelayPin2, LOW); // turn on relay 2
              toggleState_2 = 0;
              Serial.println("Device2 ON");
             else{
              digitalWrite(RelayPin2, HIGH); // turn off relay 2
              toggleState_2 = 1;
              Serial.println("Device2 OFF");
             delay(100);
      break;
      case 3:
             if(toggleState_3 == 1){
              digitalWrite(RelayPin3, LOW); // turn on relay 3
              toggleState_3 = 0;
              Serial.println("Device3 ON");
             else{
              digitalWrite(RelayPin3, HIGH); // turn off relay 3
              toggleState_3 = 1;
              Serial.println("Device3 OFF");
             delay(100);
      break;
      case 4:
             if(toggleState_4 == 1){
              digitalWrite(RelayPin4, LOW); // turn on relay 4
              toggleState_4 = 0;
              Serial.println("Device4 ON");
             else{
              digitalWrite(RelayPin4, HIGH); // turn off relay 4
              toggleState_4 = 1;
              Serial.println("Device4 OFF");
             delay(100);
      break;
      case 5:
             if(toggleState_5 == 1){
              digitalWrite(RelayPin5, LOW); // turn on relay 5
              toggleState_5 = 0;
              Serial.println("Device5 ON");
             else{
              digitalWrite(RelayPin5, HIGH); // turn off relay 5
              toggleState_5 = 1;
              Serial.println("Device5 OFF");
             delay(100);
      break;
      case 6:
             if(toggleState_6 == 1){
              digitalWrite(RelayPin6, LOW); // turn on relay 6
              toggleState_6 = 0;
              Serial.println("Device6 ON");
             else{
              digitalWrite(RelayPin6, HIGH); // turn off relay 6
              toggleState_6 = 1;
              Serial.println("Device6 OFF");
             delay(100);
      break;
      case 7:
             if(toggleState_7 == 1){
              digitalWrite(RelayPin7, LOW); // turn on relay 7
              toggleState_7 = 0;
              Serial.println("Device7 ON");
             else{
              digitalWrite(RelayPin7, HIGH); // turn off relay 7
              toggleState_7 = 1;
              Serial.println("Device7 OFF");
             delay(100);
      break;
      case 8:
             if(toggleState_8 == 1){
              digitalWrite(RelayPin8, LOW); // turn on relay 8
              toggleState_8 = 0;
              Serial.println("Device8 ON");
             else{
              digitalWrite(RelayPin8, HIGH); // turn off relay 8
              toggleState_8 = 1;
              Serial.println("Device8 OFF");
             delay(100);
      break;
      default : break;
void with_internet(){
    //Manual Switch Control
    if (digitalRead(SwitchPin1) == LOW){
      delay(200);
      relayOnOff(1);
      Blynk.virtualWrite(VPIN_BUTTON_1, toggleState_1);   // Update Button Widget
    else if (digitalRead(SwitchPin2) == LOW){
      delay(200);
      relayOnOff(2);
      Blynk.virtualWrite(VPIN_BUTTON_2, toggleState_2);   // Update Button Widget
    else if (digitalRead(SwitchPin3) == LOW){
      delay(200);
      relayOnOff(3);
      Blynk.virtualWrite(VPIN_BUTTON_3, toggleState_3);   // Update Button Widget
    else if (digitalRead(SwitchPin4) == LOW){
      delay(200);
      relayOnOff(4);
      Blynk.virtualWrite(VPIN_BUTTON_4, toggleState_4);   // Update Button Widget
    else if (digitalRead(SwitchPin5) == LOW){
      delay(200);
      relayOnOff(5);
      Blynk.virtualWrite(VPIN_BUTTON_5, toggleState_5);   // Update Button Widget
    else if (digitalRead(SwitchPin6) == LOW){
      delay(200);
      relayOnOff(6);
      Blynk.virtualWrite(VPIN_BUTTON_6, toggleState_6);   // Update Button Widget
    else if (digitalRead(SwitchPin7) == LOW){
      delay(200);
      relayOnOff(7);
      Blynk.virtualWrite(VPIN_BUTTON_7, toggleState_7);   // Update Button Widget
    else if (digitalRead(SwitchPin8) == LOW){
      delay(200);
      relayOnOff(8);
      Blynk.virtualWrite(VPIN_BUTTON_8, toggleState_8);   // Update Button Widget
void without_internet(){
   Serial.println("WiFi Not without_internet");
      delay(200);
      relayOnOff(1);
      delay(200);
      relayOnOff(2);
      delay(200);
      relayOnOff(3);
      delay(200);
      relayOnOff(4);
      delay(200);
      relayOnOff(5);
      delay(200);
      relayOnOff(6);
      delay(200);
      relayOnOff(7);
      delay(200);
      relayOnOff(8);
BLYNK_CONNECTED() {
  Blynk.syncVirtual(VPIN_BUTTON_1);
  Blynk.syncVirtual(VPIN_BUTTON_2);
  Blynk.syncVirtual(VPIN_BUTTON_3);
  Blynk.syncVirtual(VPIN_BUTTON_4);
  Blynk.syncVirtual(VPIN_BUTTON_5);
  Blynk.syncVirtual(VPIN_BUTTON_6);
  Blynk.syncVirtual(VPIN_BUTTON_7);
  Blynk.syncVirtual(VPIN_BUTTON_8);
// When App button is pushed - switch the state
BLYNK_WRITE(VPIN_BUTTON_1) {
  toggleState_1 = param.asInt();
  digitalWrite(RelayPin1, toggleState_1);
BLYNK_WRITE(VPIN_BUTTON_2) {
  toggleState_2 = param.asInt();
  digitalWrite(RelayPin2, toggleState_2);
BLYNK_WRITE(VPIN_BUTTON_3) {
  toggleState_3 = param.asInt();
  digitalWrite(RelayPin3, toggleState_3);
BLYNK_WRITE(VPIN_BUTTON_4) {
  toggleState_4 = param.asInt();
  digitalWrite(RelayPin4, toggleState_4);
BLYNK_WRITE(VPIN_BUTTON_5) {
  toggleState_5 = param.asInt();
  digitalWrite(RelayPin5, toggleState_5);
BLYNK_WRITE(VPIN_BUTTON_6) {
  toggleState_6 = param.asInt();
  digitalWrite(RelayPin6, toggleState_6);
BLYNK_WRITE(VPIN_BUTTON_7) {
  toggleState_7 = param.asInt();
  digitalWrite(RelayPin7, toggleState_7);
BLYNK_WRITE(VPIN_BUTTON_8) {
  toggleState_8 = param.asInt();
  digitalWrite(RelayPin8, toggleState_8);
void checkBlynkStatus() { // called every 3 seconds by SimpleTimer
  bool isconnected = Blynk.connected();
  if (isconnected == false) {
    wifiFlag = 1;
  //  digitalWrite(wifiLed, LOW); //Turn off WiFi LED
    Serial.println("WiFi Not Connected-11");
  if (isconnected == true) {
    wifiFlag = 0;
    //digitalWrite(wifiLed, HIGH); //Turn on WiFi LED
    Serial.println("WiFi Not Connected-12");
  pinMode(RelayPin1, OUTPUT);
  pinMode(RelayPin2, OUTPUT);
  pinMode(RelayPin3, OUTPUT);
  pinMode(RelayPin4, OUTPUT);
  pinMode(RelayPin5, OUTPUT);
  pinMode(RelayPin6, OUTPUT);
  pinMode(RelayPin7, OUTPUT);
  pinMode(RelayPin8, OUTPUT);
  pinMode(wifiLed, OUTPUT);
  pinMode(SwitchPin1, INPUT_PULLUP);
  pinMode(SwitchPin2, INPUT_PULLUP);
  pinMode(SwitchPin3, INPUT_PULLUP);
  pinMode(SwitchPin4, INPUT_PULLUP);
  pinMode(SwitchPin5, INPUT_PULLUP);
  pinMode(SwitchPin6, INPUT_PULLUP);
  pinMode(SwitchPin7, INPUT_PULLUP);
  pinMode(SwitchPin8, INPUT_PULLUP);
  //During Starting all Relays should TURN OFF
  WiFi.begin(WIFI_SSID, WIFI_PASS);
  timer.setInterval(3000L, checkBlynkStatus); // check if Blynk server is connected every 3 seconds
  //Blynk.config(AUTH);
  Blynk.begin(AUTH, WIFI_SSID, WIFI_PASS, IPAddress(192,186,10,150), 8080);
  if (WiFi.status() != WL_CONNECTED)
    Serial.println("WiFi Not Connected");
    //Serial.println("WiFi Connected");
  if (wifiFlag == 0)
    with_internet();
    without_internet();
Please edit your post and add triple backticks ( ``` ) before and after your sketch.
@Kiran_Raju please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
You aren’t updating the toggleState_x variable in your with_internet function, which seems to be causing the logic loop.
Try printing these values to the serial monitor to track the status.
Your code would be much simpler if you used the BLYNK_WRITE_DEFAULT() functionality.
