char auth[] = "xxxxxxxxxxxxxxxxxxxxxxxx2361";
char ssid[] = "Evolution";
char pass[] = "Next2309";
@fantindominic please edit your post and add triple backticks at the beginning and end of your code so that it displays correctly.
It would also be sensible for you to copy and paste your serial monitor output as well (also with triple backticks).
Serial Monitor Output:
12:16:54.821 -> $⸮⸮⸮⸮⸮⸮[75] Connecting to Evolution
@PeteKnight Thanks for the correction, I thought it was not required in this community. Hope I find my answers ASAP
Are you sure your SSID and password are correct?
They are both case sensitive.
Also, the NodeMCU can only connect to tge 2.4GHz band, not 5GHz.
Both ssid and password are Correct (network is 2.4Ghz)
Try rebooting your router and any repeaters you may have (if you do have repeaters then maybe keep them off and work near to your router, to reduce possible problem points).
Check that you have used the correct board settings when uploading your code.
Also remove any connections to the board, other than the MicroUSB cable.
If that doesn’t work then maybe your NodeMCU is faulty.
Pete
