Whent I try to compile my sketch, IDE shows the following error:
no matching function for call to 'BlynkWifi::begin(char [33])'
I was working fine with my project, connected to Blynk without any issues. But now I included WifiManager to avoid the hardcoded of the SSID and Password and this error appeared.
I’m using ESP8266 NodeMCU Lolin standalone.
Any ideas?
My full code is here:
#include <DNSServer.h>
#include <OneWire.h>
#include <TimeLib.h>
#include <WidgetRTC.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h> //https://github.com/tzapu/WiFiManager
#include <ESP8266mDNS.h>
#include <ESP8266HTTPUpdateServer.h>
#define ONE_WIRE_BUS 2 // DS18B20 pin D4(ESP8266) compatible tarjeta antigua
#define GraphTemp 8
#define VIRTUAL_PIN_Terminal 9
#define VIRTUAL_PIN_Menu_Modo 26
#define Update_Firmware 15 // Push Button virtual en Blynk para solicitar upgrade de Firmware OTA vía Http
const size_t len_curvas = 3858;
const uint8_t curvas[] PROGMEM = {----A very long binary data ---};
WidgetRTC rtc;
WidgetTerminal terminal(VIRTUAL_PIN_Terminal); // Attach virtual serial terminal to Virtual Pin
DallasTemperature DS18B20(&oneWire);
float oldTemp = -1;
float temp;
int PWM_Digital_Canal[4] = { 5, 4, 0, 2};
int VIRTUAL_PIN_Fotoperiodo_Canal[4] = { 18, 19, 20, 21};
int Graph_Canal[4] = { 10, 11, 12, 14};
int PWM_Virtual_Canal[4] = { 0, 1, 2, 3};
int Luz[4];
int luz_anterior[4];
unsigned long deltaLuz[4];
int potCanal[4] = {0, 0, 0, 0};
int ValorLuzSD;
int modoLuz = 0;
unsigned long posmem;
int Modo = 1;
String Modo_txt[5] = {"Manual", "Despejado", "Nubes Suaves", "Nubes Intensas"};
char auth[] = "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"; // My Token
int FotoPeriodo_Inicio_Canal[4] = { 300, 300, 300, 300};
int FotoPeriodo_Fin_Canal[4] = { 1320, 1320, 1320, 1320};
int Minuto_Ajustado;
const char* host = "esp8266-webupdate";
int updateWeb = 0;
ESP8266WebServer httpServer(80);
ESP8266HTTPUpdateServer httpUpdater;
void actualizaLuzTemp()
int t = now(); // Guarda la hora actual en t
String currentTime = String(hour()) + ":" + minute();
int h = hour(t); // returns the hour for the given time t
int m = minute(t);// returns the minute for the given time t
int i;
switch (Modo)
case 1:
for (i = 0; i < 4; i = i + 1)
potCanal[i] = Luz[i];
break;
default:
Minuto_Ajustado = ( h*60 + m - FotoPeriodo_Inicio_Canal[i]) * 642 / (FotoPeriodo_Fin_Canal[i] - FotoPeriodo_Inicio_Canal[i]);
if ( Minuto_Ajustado < 0 || Minuto_Ajustado > 642 ) Minuto_Ajustado = 0;
posmem = (Modo-2)*1286 + (Minuto_Ajustado)*2;
uint8_t byteval_1 = pgm_read_byte(curvas + posmem);
posmem = posmem + 1;
uint8_t byteval_2 = pgm_read_byte(curvas + posmem);
if ( Luz[i] > 100) Luz[i] = 100;
potCanal[i] = (byteval_1*256 + byteval_2)*Luz[i]/100;
if ( (luz_anterior[0] - potCanal[0]) * (luz_anterior[0] - potCanal[0]) >= 1601 )
int i;
deltaLuz[i] = ( potCanal[i] - luz_anterior[i] ) / 50;
int Conteo_Segundos = 0;
int millis_anterior = 0;
int millis_actual = 0;
terminal.println(F("-----------------"));
terminal.println(F("* Partida Suave *"));
terminal.flush();
while (Conteo_Segundos < 50)
millis_actual = millis();
yield();
if ( (millis_actual - millis_anterior) > 1000 )
millis_anterior = millis_actual;
Conteo_Segundos = Conteo_Segundos + 1;
int i;
potCanal[i] = luz_anterior[i] + deltaLuz[i];
analogWrite(PWM_Digital_Canal[i], potCanal[i]);
luz_anterior[i] = potCanal[i];
break;
for (i = 0; i < 4; i = i+1 )
Blynk.virtualWrite(Graph_Canal[i], potCanal[i]);
terminal.print("Hora: ");
terminal.print(currentTime);
leeTemperatura();
Blynk.virtualWrite(GraphTemp, temp);
terminal.println(" Temp. "+String( temp)+"°C ");
terminal.println(Modo_txt[Modo]);
terminal.print("Canal ");
terminal.print(String(i+1));
terminal.print(": ");
terminal.println(String(potCanal[i]));
terminal.flush();
void leeTemperatura()
//Captura el valor de Temperatura
do {
DS18B20.requestTemperatures();
temp = DS18B20.getTempCByIndex(0);
while (temp == 85.0 || temp == (-127.0));
if (temp != oldTemp)
oldTemp = temp;
//Inicia conexión a Wifi, si no la encuentra, se convierte en AP y espera configuración ver https://github.com/tzapu/WiFiManager
WiFiManager wifiManager; // Detección y configuración del AP
wifiManager.autoConnect("Consola_Acuario","acuario2017"); // Nombre del AP ESP8266 y credencial de acceso
// Una vez conectado a WiFi inicia Blynk con el Token predefinido
Blynk.begin(auth); //Una vez conectado a WiFi se conecta a Blynk
//Una vez conectado a Blynk notifica al terminal de la app
terminal.println();
terminal.println(F("Blynk v" BLYNK_VERSION));
terminal.println(F("** Control Luz **"));
terminal.flush();
//Inicializa el controlador y sus variables
int i;
pinMode(PWM_Digital_Canal[i], OUTPUT);
actualizaLuzTemp();
timer.setInterval(60000, actualizaLuzTemp);
setSyncInterval(10*60); // Sync interval in seconds (10 minutes)
BLYNK_WRITE(VIRTUAL_PIN_Fotoperiodo_Canal[0]) // Lee limites de Fotoperiodo
TimeInputParam t(param);
// Procesa Inicio Fotoperiodo
if (t.hasStartTime())
FotoPeriodo_Inicio_Canal[0] = t.getStartHour() * 60 + t.getStartMinute();
FotoPeriodo_Inicio_Canal[0] = 300;
// Procesa Término Fotoperiodo
if (t.hasStopTime())
FotoPeriodo_Fin_Canal[0] = t.getStopHour() * 60 + t.getStopMinute();
FotoPeriodo_Fin_Canal[0] = 1320;
BLYNK_WRITE(VIRTUAL_PIN_Fotoperiodo_Canal[1]) // Lee limites de Fotoperiodo
FotoPeriodo_Inicio_Canal[1] = t.getStartHour() * 60 + t.getStartMinute();
FotoPeriodo_Inicio_Canal[1] = 300;
FotoPeriodo_Fin_Canal[1] = t.getStopHour() * 60 + t.getStopMinute();
FotoPeriodo_Fin_Canal[1] = 1320;
BLYNK_WRITE(VIRTUAL_PIN_Fotoperiodo_Canal[2]) // Lee limites de Fotoperiodo
FotoPeriodo_Inicio_Canal[2] = t.getStartHour() * 60 + t.getStartMinute();
FotoPeriodo_Inicio_Canal[2] = 300;
FotoPeriodo_Fin_Canal[2] = t.getStopHour() * 60 + t.getStopMinute();
FotoPeriodo_Fin_Canal[2] = 1320;
BLYNK_WRITE(VIRTUAL_PIN_Fotoperiodo_Canal[3]) // Lee limites de Fotoperiodo
FotoPeriodo_Inicio_Canal[3] = t.getStartHour() * 60 + t.getStartMinute();
FotoPeriodo_Inicio_Canal[3] = 300;
FotoPeriodo_Fin_Canal[3] = t.getStopHour() * 60 + t.getStopMinute();
FotoPeriodo_Fin_Canal[3] = 1320;
BLYNK_WRITE(PWM_Virtual_Canal[0]) //Slider Canal 1. Esta funcion es llamada cada vez que se cambia el valor del slider Canal 1
int pinData = param.asInt();
if ( Modo == 1)
analogWrite(PWM_Digital_Canal[0], pinData);
Luz[0] = pinData;
BLYNK_WRITE(PWM_Virtual_Canal[1]) //Slider Canal2. Esta funcion es llamada cada vez que se cambia el valor del slider Canal 2
if ( Modo == 1)
analogWrite(PWM_Digital_Canal[1], pinData);
Luz[1] = pinData;
BLYNK_WRITE(PWM_Virtual_Canal[2]) //Slider Canal 3. Esta funcion es llamada cada vez que se cambia el valor del slider Canal 3
if ( Modo == 1)
analogWrite(PWM_Digital_Canal[2], pinData);
Luz[2] = pinData;
BLYNK_WRITE(PWM_Virtual_Canal[3]) //Slider Canal 4. Esta funcion es llamada cada vez que se cambia el valor del slider Canal 4
if ( Modo == 1)
analogWrite(PWM_Digital_Canal[3], pinData);
Luz[3] = pinData;
BLYNK_WRITE(VIRTUAL_PIN_Menu_Modo) //Menu Modo. Esta función es llamada cada vez que se cambia el menu de Modo
Modo = pinData;
switch (Modo) {
case 1:
Blynk.setProperty(PWM_Virtual_Canal_1, "max", 1023);
Blynk.setProperty(PWM_Virtual_Canal_2, "max", 1023);
Blynk.setProperty(PWM_Virtual_Canal_3, "max", 1023);
Blynk.setProperty(PWM_Virtual_Canal_4, "max", 1023);
break;
default:
Blynk.setProperty(PWM_Virtual_Canal_1, "max", 100);
Blynk.setProperty(PWM_Virtual_Canal_2, "max", 100);
Blynk.setProperty(PWM_Virtual_Canal_3, "max", 100);
Blynk.setProperty(PWM_Virtual_Canal_4, "max", 100);
break;
BLYNK_WRITE(Update_Firmware) // Activa Busqueda y ejecución de actualización de firmware
updateWeb = pinData;
if ( updateWeb == 1 )
terminal.println(F("*********************"));
terminal.println(F("Inicia Actualización"));
terminal.println(F("Dispositivo"));
terminal.print("MAC: ");
terminal.println(WiFi.macAddress());
terminal.println(F("Debe estar conectado a la misma red wifi del controlador."));
terminal.println(F("Abra el siguiente enlace y luego seleccione el archivo y presione UPDATE"));
terminal.print("http://");
terminal.print( WiFi.localIP());
terminal.print("/update");
terminal.flush();
Blynk.disconnect();
MDNS.begin(host);
httpUpdater.setup(&httpServer);
httpServer.begin();
MDNS.addService("http", "tcp", 80);
BLYNK_CONNECTED() {
// Synchronize time on connection
rtc.begin();
Blynk.syncAll();
terminal.println(F("*Blynk Connected*"));
terminal.flush();
httpServer.handleClient();
