Hello. I’ve bought a Google Home Mini and I’m trying to make it work with Blynk. I am using IFTTT but it doesn’t seem to work with Digital Pins, only with Virtual Pins. Here’s the IFTTT config:
Are you using a NodeMCU or Wemos D1 Mini?
What device have you selected in the app when you created your project?
I can’t remember exactly how it works, but there’s a chance that if you reference pin D1 then it may change pin GPIO 1, or the pin labelled D1 on the board (which are different with a NodeMCU/Wemos).
You should experiment with various settings (using GET preferably) and work-out the correct way of doing it.
