Total newbie here and I don’t know if I can do this or not.
I have two pond pumps with controllers ( ESP32) connecting to blynk via aquascape. I know the auth code for both pumps. I was wondering if there was any way to create devices in blynk to connect to these two pumps.
My ultimate goal is to be able to control the pumps from Home Assistant/blynk rather than have multiple apps that I have to use to control items around my house.
This probably means nothing but I am able to get the pump speed by using this command: https://smartcontrol.aquascapeinc.com/external/api/get?token=MyToken&v2 but I haven’t been able to change the speed using a similar command. So I started to look at blynk to see if I might be able control the pump speed using blynk.
