I would like to be able to use a simple slider switch like the widgets have in their setup
eg ‘send values on release only OFF / ON’
eg ‘Mode PUSH / SWITCH’
You can simulate this with a slider with values 0 and 1 but its not really boolean and you cant lable it so clearly.
I have trouble with the standard buttons because I get confused if that is what the setting currently is
or that is what will occur if I press the button. Like the dvd buttons for pause / play - its always what will happen next
Anyway the oval slider is much clearer in my opinion - and it is already used in the app.
JC
