I want to control relay
I have a arduino uno and esp8266-01 module.
I want to control relay.Help me please.
Welcome to the Blynk forum.
Start with this documentation for connecting the ESP and UNO:
http://help.blynk.cc/how-to-connect-different-hardware-with-blynk/arduino/esp8266-with-at-firmware
Other links to the Documents, Help Center and Sketch Examples are available at the upper right of this page.
Can i try it without using USB-UART TTL converter?
Yes but it’s difficult to debug any problems without Serial Monitor.
Wouldn’t recommend using an Uno and 01 to control a relay with Blynk.
Just use the ESP01 in standalone mode.
if i use esp01 in standalone mode,UNO can be a programmer?
Yes I believe it can be set up in place of a USB2TTL adapter.
you probably should buy something like this, it is much cleaner way to upload flash.
