#include <ESP8266WebServer.h>
#include <DNSServer.h>
#include <WiFiManager.h>
#include <Ticker.h>
Ticker ticker;
char auth[] = "b95VF34kHBcaUV75AhPGoUU_QYjShn8c"; // You should get Auth Token in the Blynk App.
#define TRIGGER_PIN 0 // Button Reset Network ( Pin D3 )
#define LED_PIN 2 // LED connection status ( Pin D4 )
void tick()
int state = digitalRead(LED_PIN);
digitalWrite(LED_PIN, !state);
void configModeCallback (WiFiManager *myWiFiManager) {
ticker.attach(0.2, tick);
pinMode(TRIGGER_PIN, INPUT);
pinMode(LED_PIN, OUTPUT);
WiFiManager wifiManager;
ticker.attach(0.6, tick);
wifiManager.setAPCallback(configModeCallback);
if (!wifiManager.autoConnect("آلترا سمارت")) { // your ap name
ESP.reset();
ticker.detach();
digitalWrite(LED_PIN, HIGH);
Blynk.config(auth);
int count = 0;
while(digitalRead(TRIGGER_PIN) == LOW) {
delay(100);
count++;
if(count > 30) {
WiFi.disconnect();
digitalWrite(LED_PIN, LOW);
count = 0;
delay(100);
ESP.reset();
Please edit your post to add triple backticks at the beginning and end of your code so that it displays correctly.
Please excuse me but I don’t know how to do it. My language is not English. I have difficulty dealing with the forum
Mr. Pete I searched at length for a way to add auth to the WiFi Manager page and I couldn’t make it
Do you know how to copy and paste?
Edit your post using the pencil icon at the bottom of your first post and paste the triple backticks from my post to a blank line at the beginning and end of your code.
I did it
You seem to be missing quite a lot of important code that is needed to make WiFiManager work, even for storing SSID and password.
I’d suggest that you take a look at this:
It’s useless you’ve tried
My code works fine but lacks the auth add in the WiFi manager page
Есть вариант для Blynk. Видео на русском языке.
You will need to reset the settings in case the router password is changed
Please help by adding this feature
@wasemooo4, your replies don’t seem to make much sense, and comments like this come across as being quite rude:
I appreciate that English may not be your first language, but I think you may need to take more effort with your translation, or make your posts in your own language.
Looks like you misunderstood my sorry if my response was rude
