I figure it might help others that connect to multiple servers / ports
#!/usr/bin/env node
var Blynk = require("../");
if (process.argv[2]) {
if ((process.argv[2]=="-h") || (process.argv[2]=="--h")) {
printusage();
process.exit(1);
if ((process.argv[2]=="-help") || (process.argv[2]=="--help")) {
printusage();
process.exit(1);
if ((process.argv[2]) && (process.argv[2].length != 32)) {
console.log("");
console.log("Looks like you're TOKEN is Off by a few characters - Recopy");
console.log("");
printusage();
process.exit(1);
function printusage () {
var examf = "Example ";
var examb = "blynk-client abcdefghijklmnopqrstuvxyz12345678 ";
var exams = "192.168.1.99 ";
var examp1 = "8080 ";
var examp2 = "9443 ";
var exam1 = ": Blynk Cloud";
var exam2 = ": LocalServer / Port";
var exam3 = ": LocalServer / Port / Use SSL";
var exam4 = ": Blynk Cloud / Port / Use SSL";
var examT = "Usage : blynk-client <auth> (optional) <server> <port> <ssl>";
console.log("");
console.log(examT);
console.log("");
console.log(examf, exam1);
console.log(" ", examb);
console.log("");
console.log(examf, exam2);
console.log(" ", examb, exams, examp1);
console.log("");
console.log(examf, exam3);
console.log(" ", examb, exams, examp2, "ssl");
console.log("");
console.log(examf, exam4);
console.log(" ", examb, "blynk-cloud.com", "8441", "ssl");
console.log("");
process.exit(1);
if ((process.argv[2]) && (process.argv[3]) && (process.argv[4]) && (process.argv[5] == 'ssl')) {
console.log("");
console.log("Auth =",process.argv[2]);
console.log("Server =",process.argv[3]);
console.log("Port =",process.argv[4]);
console.log("SSL = ON");
var blynk = new Blynk.Blynk(process.argv[2], options = {
connector : new Blynk.SslClient( options = { addr: process.argv[3], port: process.argv[4]} )
if ((process.argv[2]) && (process.argv[3]) && (process.argv[4]) && (!process.argv[5])) {
console.log("");
console.log("SSL = OFF");
connector : new Blynk.TcpClient( options = { addr: process.argv[3], port: process.argv[4]} )
if ((process.argv[2]) && (process.argv[3]) && (!process.argv[4])) {
console.log("");
console.log("Port = Unspecified - Using 8080");
connector : new Blynk.TcpClient( options = { addr: process.argv[3], port: "8080"} )
// if ((process.argv[2]) && (!process.argv[3])) {
// console.log("");
// console.log("Auth =",process.argv[2]);
// console.log("Server = blynk-cloud.com");
// console.log("Port = CHANGE - Using 8441");
// console.log("SSL = ON");
// var blynk = new Blynk.Blynk(process.argv[2], options = {
// connector : new Blynk.SslClient( options = { addr:"blynk-cloud.com", port: "8441"} )
console.log("");
console.log("Port = CHANGE - Using 8080");
connector : new Blynk.TcpClient( options = { addr:"blynk-cloud.com", port: "8080"} )
if (!process.argv[2]) {
printusage();
process.exit(1);
blynk.on('connect', function() {
console.log("Blynk ready.");
