i have a production nodemcu/blynk solution running, and have encountered a problem with the handling of one sensors data. I have developed a ‘fix’, but I want to test it locally before installing onsite…
but I have only one project… do I have to create another one for this test instance?
do I comment out the blynk calls in the sketch as art of the test process? (if !debug…do production code…)
Work it out. You can see the cost of each widget in the widget box, go through your project and make a list ofthe widgets you’ve used different add up the cost.
