BLYNK
BLYNK.IO       📲 GETTING STARTED       📗 DOCS       ❓HELP CENTER       👉 SKETCH BUILDER
I need to stop function after X seconds
I already set up wifi connection to my shutters at home. And for controlling i’m using voice control via Tasker app. So when i said to google assistant to close my shutters it works fine. But after all closed i have to say “shutters okay” to switch off the relays to prevent any motor damage in shutters. I just want to add 15 seconds to the end of relay on position code. With that when i said “close the shutters” it will be closed and after 15 seconds relay will be switched the close position automaticly. Is there a any way to solve that problem.
Hardware is ESP8266-01
You need to use a BlynkTimer in timeout mode within your sketch. The simplest way to do this is as a Lambda function.
Read the timeout Timers section of this tutorial…
Thank you Pete.
I just read that article and solved. For other person who need helps on that topic, here is my code. I solved it with adding new “void” function.
char auth[] = "*******************************";
char ssid[] = "*********";
char pass[] = "***********************";
char server[] = "blynk-cloud.com";
int port = 8080;
int out1=0;
int before1;
int out2=2;
int before2;
void setup(){
  before1=1;
  pinMode(out1,OUTPUT);
  before2=1;
  pinMode(out2,OUTPUT);
  digitalWrite(out1, HIGH); //Making the pins high to keep the relay board off (for active low relays)
  digitalWrite(out2, HIGH); // make it LOW for active high relay boards.
 Blynk.begin(auth, ssid, pass, server, port);
void before11(){
  digitalWrite(out1,HIGH);
  before1=1;
  Blynk.virtualWrite(V5,0);
void before21(){
  before2=1;
  Blynk.virtualWrite(V6,0);
BLYNK_WRITE(V5)    // Virtual pin 1 to contlor relay 1
  int pinData = param.asInt();
  if (pinData==1){
      digitalWrite(out1,LOW); //relay1 is now turned on
      before1=0;
      timer.setTimeout(15000L,before11);
    if (pinData==0){
      digitalWrite(out1,HIGH); //relay1 is now turned off
      before1=1;
BLYNK_WRITE(V6) // Virtual pin 2 to contlor relay 2
  if (pinData==1){
      digitalWrite(out2,LOW);
      before2=0;
      timer.setTimeout(15000L,before21);
    if (pinData==0){
      digitalWrite(out2,HIGH);
      before2=1;
@CaptainOnedin please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
Done :innocent:
The Lambda function is usually much neater.
Yeap, it seems like. I’ll try that also. Thank you @PeteKnight
Also, anyone planning on using this sketch should be aware that it’s a Blynk Legacy sketch and will need modification before it can be used with Blynk IoT.
