Hi, I need help.
my code works perfectly during the day, but at the beginning of a new day the code gets lost.
for example:
I have a schedule with start 64800 ms or 18h
on the new day when nowSeconds is at 648ms the code executes as 64800ms
this problem occurs in
void lighting(){
and
void timerControl(){
#include <Ethernet.h>
#include <WidgetRTC.h>
#include <OneWire.h>
BlynkTimer timer; // Object BlynkTimer (SimpleTimer)
WidgetRTC rtc;
char auth[] = "8cad"; // Token Blynk Server
#define W5100_CS 10
#define SDCARD_CS 4
// Define Define
const int porta01 = 24; // relay WaveMaker 1
const int porta02 = 25; // relay WaveMaker 2
const int porta03 = 26; // relay UV filter
const int porta04 = 27; // relay light on/off
const int controle = 28; // relay Control
const int alarme = 29; // relay Alarm
const int led01 = 2; // led Day (white)
const int led02 = 3; // led Night (blue)
int rele01State = HIGH; // Start Relay 01
int rele02State = HIGH; // Start Relay 02
int rele03State = HIGH; // Start Relay 03
int rele04State = HIGH; // Start Relay 04
int rele05State = HIGH; // Start Relay 05
int rele06State = HIGH; // Start Relay 06
// Temperature Sensor
#define ONE_WIRE_BUS 22 // Define GPIO 22 to Temperature Sensor
DallasTemperature DS18B20(&oneWire);
float temp;
String nowSeconds;
void setup(){
Blynk.begin(auth, IPAddress(10,12,25,100), 8080);
//Blynk.begin(auth, "blynk.com.br", 6008);
while (Blynk.connect() == false){ //Aguardando o Blynk Local Server se conectar
pinMode(porta01, OUTPUT); // Declares pin 24 as output
pinMode(porta02, OUTPUT); // Declares pin 25 as output
pinMode(porta03, OUTPUT); // Declares pin 26 as output
pinMode(porta04, OUTPUT); // Declares pin 27 as output
pinMode(controle, OUTPUT); // Declares pin 28 as output
pinMode(alarme, OUTPUT); // Declares pin 29 as output
pinMode(led01, OUTPUT); // Declares pin 2 as output
pinMode(led02, OUTPUT); // Declares pin 3 as output
digitalWrite(controle, rele01State); //Receives initial status of Relay 01
digitalWrite(alarme, rele02State); //Receives initial status of Relay 02
digitalWrite(porta01, rele03State); //Receives initial status of Relay 03
digitalWrite(porta02, rele04State); //Receives initial status of Relay 04
digitalWrite(porta03, rele05State); //Receives initial status of Relay 05
digitalWrite(porta04, rele06State); //Receives initial status of Relay 06
pinMode(SDCARD_CS, OUTPUT);
digitalWrite(SDCARD_CS, HIGH); // Deselect the SD card
DS18B20.begin(); // Initializes the temperature sensor
setSyncInterval(30 * 60); // Sets the time synchronization interval
// Schedules
timer.setInterval(2000L, clockDisplay); // Display digital clock every 5 seconds
timer.setInterval(5000L, lighting); // Lighting timer 10 seconds
timer.setInterval(5000L, timerControl); // WaveMaker Timer Control 10 seconds
timer.setInterval(10000L, sendTemp); // Temperature Monitor 10 seconds
// Synchronize App ports
BLYNK_CONNECTED(){
Serial.println("CONNECTED");
Blynk.syncAll();
rtc.begin(); // Start RTC Widget
void loop(){
// Controle Leds
// Led Parameters
int pw0 = 0;
int pw1 = 5;
int pw2 = 10;
int pw3 = 25;
int pw4 = 50;
int pw5 = 75;
int pw6 = 100;
int pw7 = 125;
int pw8 = 150;
int pw9 = 175;
int pw10 = 200;
int pw11 = 225;
String sch0MLed;
String sch1MLed;
String sch2MLed;
String sch3MLed;
String sch4MLed;
String sch5MLed;
String sch6MLed;
String sch7MLed;
String sch8MLed;
String sch9MLed;
String sch10MLed;
String sch0NLed;
String sch1NLed;
String sch2NLed;
String sch3NLed;
String sch4NLed;
String sch5NLed;
String sch6NLed;
String sch7NLed;
String sch8NLed;
String sch9NLed;
String sch10NLed;
String startLedTimer;
String stopLedTimer;
String ledOff;
BLYNK_WRITE(V9){ // Function that changes the state of Relay 01 when the button in the APP is pressed
rele06State = param.asInt(); // Variable receives and stores APP data
digitalWrite(porta04, rele06State); // Change the status of Relay 01
int SThour;
int STmin;
int STsec;
int SPhour;
int SPmin;
int SPsec;
BLYNK_WRITE(V27) {
TimeInputParam t(param);
SThour = t.getStartHour();
STmin = t.getStartMinute();
STsec = t.getStartSecond();
SPhour = t.getStopHour();
SPmin = t.getStopMinute();
SPsec = t.getStopSecond();
if (t.hasStartTime()){
startLedTimer = (t.getStartHour() * 3600L + t.getStartMinute() * 60);
Serial.print("LED - Start Timer - ");
Serial.println(startLedTimer);
else{
// Do nothing
if (t.hasStopTime()){
stopLedTimer = (t.getStopHour() * 3600L + t.getStopMinute() * 60);
Serial.print("LED - Stop Timer - ");
Serial.println(stopLedTimer);
else{
// Do nothing: no stop time was set
BLYNK_WRITE(V28){
ledOff = param[0].asLong();
Serial.println("ledOff");
Serial.println(ledOff);
// RTC
// Define RTC
const String DayOfWeek[7] = {"Dom", "Seg", "Ter", "Qua", "Qui", "Sex", "Sab"};
const String Month[12] = {"Jan", "Fev", "Mar", "Abr", "Mai", "Jun", "Jul", "Ago", "Set", "Out", "Nov", "Dez"};
String showWeek;
String showMonth;
String currentTime;
String currentDate;
// Digital clock display of the time
String printDigits(int digits){
String new_digits;
if (digits < 10) {
new_digits += "0";
new_digits += String(digits);
return new_digits;
void clockDisplay(){
showWeek = DayOfWeek[weekday()-1];
showMonth = Month[month()-1];
currentTime = String(printDigits(hour())) + ":" + printDigits(minute()) + ":" + printDigits(second());
currentDate = String(showWeek) + " - " + printDigits(day()) + "/" + showMonth + "/" + year();
Serial.print(showWeek);
Serial.print(" ");
Serial.print(currentTime);
Serial.print(" ");
Serial.print(currentDate);
Serial.println();
// Send time to the App
Blynk.virtualWrite(V1, currentTime);
// Send date to the App
Blynk.virtualWrite(V2, currentDate);
* Run the Leds Schedule
void lighting(){
// String newDay = "00001";
// String endDay = "86400L";
nowSeconds = (hour() * 3600L + minute() * 60 + second());
sch0MLed = (SThour * 3600L + STmin * 60 + STsec);
sch1MLed = (SThour * 3600L + STmin * 60 + STsec + 300);
sch2MLed = (SThour * 3600L + STmin * 60 + STsec + 900);
sch3MLed = (SThour * 3600L + STmin * 60 + STsec + 1200);
sch4MLed = (SThour * 3600L + STmin * 60 + STsec + 1500);
sch5MLed = (SThour * 3600L + STmin * 60 + STsec + 1800);
sch6MLed = (SThour * 3600L + STmin * 60 + STsec + 2100);
sch7MLed = (SThour * 3600L + STmin * 60 + STsec + 2400);
sch8MLed = (SThour * 3600L + STmin * 60 + STsec + 2700);
sch9MLed = (SThour * 3600L + STmin * 60 + STsec + 3000);
sch10MLed = (SThour * 3600L + STmin * 60 + STsec + 3300);
sch0NLed = (SPhour * 3600L + SPmin * 60 + SPsec);
sch1NLed = (SPhour * 3600L + SPmin * 60 + SPsec + 300);
sch2NLed = (SPhour * 3600L + SPmin * 60 + SPsec + 900);
sch3NLed = (SPhour * 3600L + SPmin * 60 + SPsec + 1200);
sch4NLed = (SPhour * 3600L + SPmin * 60 + SPsec + 1500);
sch5NLed = (SPhour * 3600L + SPmin * 60 + SPsec + 1800);
sch6NLed = (SPhour * 3600L + SPmin * 60 + SPsec + 2100);
sch7NLed = (SPhour * 3600L + SPmin * 60 + SPsec + 2400);
sch8NLed = (SPhour * 3600L + SPmin * 60 + SPsec + 2700);
sch9NLed = (SPhour * 3600L + SPmin * 60 + SPsec + 3000);
sch10NLed = (SPhour * 3600L + SPmin * 60 + SPsec + 3300);
// Day Control
if(nowSeconds >= startLedTimer && nowSeconds < ledOff){
digitalWrite(porta04, LOW);
if(rele06State == LOW){
if(nowSeconds >= startLedTimer && nowSeconds < stopLedTimer){
if(nowSeconds >= sch0MLed && nowSeconds < sch1MLed){
Serial.print("sch0MLed - ");
Serial.println(sch0MLed);
analogWrite(led01, pw2);
analogWrite(led02, pw0);
else if(nowSeconds >= sch1MLed && nowSeconds < sch2MLed){
Serial.print("sch1MLed - ");
Serial.println(sch1MLed);
analogWrite(led01, pw3);
else if(nowSeconds >= sch2MLed && nowSeconds < sch3MLed){
Serial.print("sch2MLed - ");
Serial.println(sch2MLed);
analogWrite(led01, pw4);
else if(nowSeconds >= sch3MLed && nowSeconds < sch4MLed){
Serial.print("sch3MLed - ");
Serial.println(sch3MLed);
analogWrite(led01, pw5);
else if(nowSeconds >= sch4MLed && nowSeconds < sch5MLed){
Serial.print("sch4MLed - ");
Serial.println(sch4MLed);
analogWrite(led01, pw6);
else if(nowSeconds >= sch5MLed && nowSeconds < sch6MLed){
Serial.print("sch5MLed - ");
Serial.println(sch5MLed);
analogWrite(led01, pw7);
else if(nowSeconds >= sch6MLed && nowSeconds < sch7MLed){
Serial.print("sch6MLed - ");
Serial.println(sch6MLed);
analogWrite(led01, pw8);
else if(nowSeconds >= sch7MLed && nowSeconds < sch8MLed){
Serial.print("sch7MLed - ");
Serial.println(sch7MLed);
analogWrite(led01, pw9);
else if(nowSeconds >= sch8MLed && nowSeconds < sch9MLed){
Serial.print("sch8MLed - ");
Serial.println(sch8MLed);
analogWrite(led01, pw10);
else if(nowSeconds >= sch9MLed && nowSeconds < sch10MLed){
Serial.print("sch9MLed - ");
Serial.println(sch9MLed);
else if(nowSeconds >= sch10MLed && nowSeconds < stopLedTimer){
Serial.print("sch10MLed - ");
Serial.println(sch10MLed);
// Night Control
else if(nowSeconds >= stopLedTimer && nowSeconds < ledOff){
if(nowSeconds >= sch0NLed && nowSeconds < sch1NLed){
Serial.print("sch0NLed - ");
Serial.println(sch0NLed);
analogWrite(led02, pw2);
else if(nowSeconds >= sch1NLed && nowSeconds < sch2NLed){
Serial.print("sch1NLed - ");
Serial.println(sch1NLed);
analogWrite(led02, pw4);
else if(nowSeconds >= sch2NLed && nowSeconds < sch3NLed){
Serial.print("sch2NLed - ");
Serial.println(sch2NLed);
analogWrite(led02, pw6);
else if(nowSeconds >= sch3NLed && nowSeconds < sch4NLed){
Serial.print("sch3NLed - ");
Serial.println(sch3NLed);
analogWrite(led02, pw8);
else if(nowSeconds >= sch4NLed && nowSeconds < sch5NLed){
Serial.print("sch4NLed - ");
Serial.println(sch4NLed);
analogWrite(led02, pw10);
else if(nowSeconds >= sch5NLed && nowSeconds < sch6NLed){
Serial.print("sch5NLed - ");
Serial.println(sch5NLed);
analogWrite(led01, pw1);
analogWrite(led02, pw11);
else if(nowSeconds >= sch6NLed && nowSeconds < sch7NLed){
Serial.print("sch6NLed - ");
Serial.println(sch6NLed);
analogWrite(led01, pw0);
else if(nowSeconds >= sch7NLed && nowSeconds < sch8NLed){
Serial.print("sch7NLed - ");
Serial.println(sch7NLed);
else if(nowSeconds >= sch8NLed && nowSeconds < sch9NLed){
Serial.print("sch8NLed - ");
Serial.println(sch8NLed);
else if(nowSeconds >= sch9NLed && nowSeconds < sch10NLed){
else if(nowSeconds >= sch10NLed && nowSeconds < ledOff){
Serial.print("sch10NLed - ");
Serial.println(sch10NLed);
analogWrite(led02, pw1);
else if(rele06State == HIGH){
Serial.println("ledOff...");
digitalWrite(porta04, HIGH);
else{
Serial.println("Relay Led Off...");
// Controle Temperatura
int delta1Max = 0;
int delta2Max = 0;
int delta1Min = 0;
int delta2Min = 0;
BLYNK_WRITE(V12){ // Function Delta 1 Min
delta1Min = param.asInt(); // Variable receives and stores APP data
BLYNK_WRITE(V13){ // Function Delta 2 Min
delta2Min = param.asInt(); // Variable receives and stores APP data
BLYNK_WRITE(V14){ // Function Delta 1 Max
delta1Max = param.asInt(); // Variable receives and stores APP data
BLYNK_WRITE(V15){ // Function Delta 2 Max
delta2Max = param.asInt(); // Variable receives and stores APP data
// Instructions for sending Temperature data
void sendTemp(){
DS18B20.requestTemperatures();
temp = DS18B20.getTempCByIndex(0);
Serial.println(temp);
Blynk.virtualWrite(V10,temp); // Virtual Port 10 graphic
Blynk.virtualWrite(V11,temp); // Virtual Port 11 real time
if(temp > delta2Min && temp < delta1Max){
Blynk.virtualWrite(V6, 0); // Led Control
Blynk.virtualWrite(V7, 0); // Led Alarm
Serial.println("Control and Alarm Off");
digitalWrite(controle, HIGH);
digitalWrite(alarme, HIGH);
else if(temp < delta1Min && temp <= delta2Min ){
Blynk.virtualWrite(V6, 1023); // Led Control
Serial.println("Control On");
digitalWrite(controle, LOW);
else if(temp > delta1Max && temp >= delta2Max){
Blynk.virtualWrite(V7, 1023); // Led Alarm
Serial.println("Alarm On");
digitalWrite(alarme, LOW);
//else{
//Blynk.virtualWrite(V6, 0); // Led Control
//Blynk.virtualWrite(V7, 0); // Led Alarm
//digitalWrite(controle, HIGH);
//digitalWrite(alarme, HIGH);
// Timer Bombas
String startTimer1;
String stopTimer1;
String startTimer2;
String stopTimer2;
String startTimer3;
String stopTimer3;
String startTimer4;
String stopTimer4;
String startTimer5;
String stopTimer5;
String startTimer6;
String stopTimer6;
BLYNK_WRITE(V21){ // Schedule 1 WaveMaker 1
startTimer1 = (t.getStartHour() * 3600L + t.getStartMinute() * 60) + t.getStartSecond();
else{
// Do nothing
stopTimer1 = (t.getStopHour() * 3600L + t.getStopMinute() * 60 + t.getStartSecond());
else{
BLYNK_WRITE(V22){ // Schedule 2 WaveMaker 1
startTimer2 = (t.getStartHour() * 3600L + t.getStartMinute() * 60 + t.getStartSecond());
else{
// Do nothing
stopTimer2 = (t.getStopHour() * 3600L + t.getStopMinute() * 60 + t.getStartSecond());
else{
BLYNK_WRITE(V23){ // Schedule 1 WaveMaker 2
startTimer3 = (t.getStartHour() * 3600L + t.getStartMinute() * 60 + t.getStartSecond());
else{
// Do nothing
stopTimer3 = (t.getStopHour() * 3600L + t.getStopMinute() * 60 + t.getStartSecond());
else{
BLYNK_WRITE(V24){ // Schedule 2 WaveMaker 2
startTimer4 = (t.getStartHour() * 3600L + t.getStartMinute() * 60 + t.getStartSecond());
else{
// Do nothing
stopTimer4 = (t.getStopHour() * 3600L + t.getStopMinute() * 60 + t.getStartSecond());
else{
BLYNK_WRITE(V25){ // Schedule 1 UV Filter
startTimer5 = (t.getStartHour() * 3600L + t.getStartMinute() * 60 + t.getStartSecond());
else{
// Do nothing
stopTimer5 = (t.getStopHour() * 3600L + t.getStopMinute() * 60 + t.getStartSecond());
else{
BLYNK_WRITE(V26){ // Schedule 2 UV Filter
startTimer6 = (t.getStartHour() * 3600L + t.getStartMinute() * 60 + t.getStartSecond());
else{
// Do nothing
stopTimer6 = (t.getStopHour() * 3600L + t.getStopMinute() * 60 + t.getStartSecond());
else{
int sch1 = (nowSeconds >= "startTimer1" && nowSeconds < "stopTimer1");
int sch2 = (nowSeconds >= startTimer2 && nowSeconds < stopTimer2);
int sch3 = (nowSeconds >= startTimer3 && nowSeconds < stopTimer3);
int sch4 = (nowSeconds >= startTimer4 && nowSeconds < stopTimer4);
int sch5 = (nowSeconds >= startTimer5 && nowSeconds < stopTimer5);
int sch6 = (nowSeconds >= startTimer6 && nowSeconds < stopTimer6);
if(sch1 || sch2 || sch3 || sch4 || sch5 || sch6){
Serial.println("Active Scheduling");
// Schedule 1 e 2 WaveMaker 1
if(sch1){
Serial.print("Schedule 1 - Started - ");
Serial.print("Now Seconds");
Serial.print(" - ");
Serial.print(nowSeconds);
Serial.print("Start Timer");
Serial.println(startTimer1);
Blynk.virtualWrite(V3, 1023);
digitalWrite(porta01, LOW);
else if(sch2){
Serial.print("Schedule 2 - Started - ");
Serial.println(startTimer2);
else{
Blynk.virtualWrite(V3, 0);
digitalWrite(porta01, HIGH);
// Schedule 3 e 4 WaveMaker 2
if(sch3){
Serial.print("Schedule 3 - Started - ");
Serial.println(startTimer3);
Blynk.virtualWrite(V4, 1023);
digitalWrite(porta02, LOW);
else if(sch4){
Serial.print("Schedule 4 - Started - ");
Serial.println(startTimer4);
else{
Blynk.virtualWrite(V4, 0);
digitalWrite(porta02, HIGH);
// Schedule 5 - 6 UV Filter
if(sch5){
Serial.print("Schedule 5 - Started - ");
Serial.println(startTimer5);
Blynk.virtualWrite(V5, 1023);
digitalWrite(porta03, LOW);
else if(sch6){
Serial.print("Schedule 6 - Started - ");
Serial.println(startTimer6);
else{
Blynk.virtualWrite(V5, 0);
digitalWrite(porta03, HIGH);
else{
Serial.println("No Active Scheduling");
sorry my poor english!
