The condition is press button 1 relay 1 on and wait unit till press button 1 relay 1 off. How to fix it. Thank you very much.
My code
#include <ESP8266WiFiMulti.h>
#include <WiFiManager.h>
ESP8266WiFiMulti wifiMulti;
#include <SimpleTimer.h> //Blynk
#define WIFI_LED 13
char auth[] = "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX";
char server[] = "XXXXXXXXXXX";
char ssid[] = "ArcHeR-OMEN";
//char ssid[] = "ArcHeR";
char pass[] = "XXXXXXXXX";
int port = 8080;
bool isFirstConnect = true;
int slider;
char Button1 = 0;
char Button2 = 9;
char Button3 = 10;
char Button4 = 14;
char Relay1 = 12;
char Relay2 = 5;
char Relay3 = 4;
char Relay4 = 15;
int buttonState1 = 0; // variable for reading the pushbutton status
int buttonState2 = 0;
int buttonState3 = 0;
int buttonState4 = 0;
BLYNK_CONNECTED() {
if (isFirstConnect) {
Blynk.syncAll();
//Blynk.notify("Device 2 Starting!!!!");
isFirstConnect = false;
Serial.println(String("แอพเริ่มทำงาน!!")); // used for debugging
Serial.println("\n Starting");
wifiMulti.addAP(ssid, pass);
Serial.println("SSID1");
Blynk.config(auth, server, port);
Blynk.connect(); // for a local server requiring WiFi connection
pinMode(WIFI_LED, OUTPUT);
pinMode(Button1, INPUT);
pinMode(Button2, INPUT);
pinMode(Button3, INPUT);
pinMode(Button4, INPUT);
pinMode(Relay1, OUTPUT);
pinMode(Relay2, OUTPUT);
pinMode(Relay3, OUTPUT);
pinMode(Relay4, OUTPUT);
digitalWrite(Button1, LOW);
digitalWrite(Button2, LOW);
digitalWrite(Button3, LOW);
digitalWrite(Button4, LOW);
digitalWrite(Relay1, LOW);
digitalWrite(Relay2, LOW);
digitalWrite(Relay3, LOW);
digitalWrite(Relay4, LOW);
Serial.println("Connecting Wifi...");
if(wifiMulti.run() == WL_CONNECTED) {
Serial.println("");
Serial.println("IP address: ");
timer.setInterval(15000, reconnectBlynk); // check every 15 seconds if we are connected to the server
void reconnectBlynk() // reconnect to server if disconnected, timer checks every 15 seconds
if (!Blynk.connected()) {
if(Blynk.connect()) {
BLYNK_LOG("Reconnected");
digitalWrite(WIFI_LED,LOW);
BLYNK_LOG("Not reconnected");
digitalWrite(WIFI_LED,HIGH);
if (Blynk.connected()) { // to ensure that Blynk.run() function is only called if we are still connected to the server
if(wifiMulti.run() != WL_CONNECTED) {
Serial.println("WiFi not connected!");
buttonState1 = digitalRead(Button1);
buttonState2 = digitalRead(Button2);
buttonState3 = digitalRead(Button3);
buttonState4 = digitalRead(Button4);
if (buttonState1 == HIGH) {
// turn LED on:
digitalWrite(Relay1, HIGH);
// turn LED off:
if (buttonState2 == HIGH) {
// turn LED on:
digitalWrite(Relay2, HIGH);
// turn LED off:
if (buttonState3 == HIGH) {
// turn LED on:
digitalWrite(Relay3, HIGH);
// turn LED off:
if (buttonState4 == HIGH) {
// turn LED on:
digitalWrite(Relay4, HIGH);
// turn LED off:
result
