Whent I try to compile my sketch, IDE shows the following error:
no matching function for call to 'BlynkTimer::setInterval(long int, float&)'
I’m using ESP8266 NodeMCUMOD
I am a newbie at this so most of the codes are just taken from the net and tweaked a bit to match my project
Any ideas?
My full code is here:
//#include <Timer.h> //'timer' does not name a type
//#define Timer t
#define SimpleTimer_H
char auth[] = "";
char ssid[] = "";
char pass[] = "";
BlynkTimer t;
float Timer1 = 0;
String myString; // complete message from arduino, which consistors of snesors data
char cdata; // received charactors
float WATER; // sensors
// This function sends Arduino's up time every second to Virtual Pin (1).
void myTimerEvent()
Blynk.virtualWrite(V0, millis() / 1000);
//Timer= timer;
Blynk.begin (auth, ssid, pass);
Timer1 = t.setInterval(1000L,WATER);
void loop() /////////////////////////////////////////////////////////////
//Timer = timer;
if (Serial.available() == 0 )
t.run(); // Initiates BlynkTimer
if (Serial.available() > 0 )
cdata = Serial.read();
myString = myString+ cdata;
// Serial.print(rdata);
if( cdata == '\n')
// Serial.println(myString);
// Serial.println("fahad");
// new code
String l = getValue(myString, ',', 0);
WATER = l.toFloat();
myString = "";
// end new code
void water()
float sdata1 = WATER;
Blynk.virtualWrite(V0, sdata1);
String getValue(String cdata, char separator, int index)
int found = 0;
int strIndex[] = { 0, -1 };
int maxIndex = cdata.length() - 1;
for (int i = 0; i <= maxIndex && found <= index; i++) {
if (cdata.charAt(i) == separator || i == maxIndex) {
found++;
strIndex[0] = strIndex[1] + 1;
strIndex[1] = (i == maxIndex) ? i+1 : i;
return found > index ? cdata.substring(strIndex[0], strIndex[1]);
