"I have serial communication between Arduino and ESP32, with sensors connected to the Arduino. I need to send data from these sensors to my Blynk app."
esp code :
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#define BLYNK_TEMPLATE_ID "TM*******c"
#define BLYNK_TEMPLATE_NAME "***********"
#define BLYNK_AUTH_TOKEN "*************"
const char* ssid = "D-Link";
const char* password = "********";
char auth[] = "********g";
  Serial.begin(9600);  // Start serial communication
  delay(1000);  // Delay to let the serial settle
  Serial.println("Starting...");
  // Connect to WiFi
  WiFi.begin(ssid, password);
  Serial.print("Connecting to WiFi");
    delay(500);
    Serial.print(".");
  // Initialize Blynk
  Blynk.begin(auth, ssid, password);
  Serial.println("Blynk initialized");
  // Setup a function to send data to Blynk every second
  timer.setInterval(1000L, sendSensorData);
  Blynk.run();  // Run Blynk
  timer.run();  // Run the timer
void sendSensorData() {
  if (Serial.available() > 0) {
    String data = Serial.readStringUntil('\n');
    Serial.println("Received data: " + data);
    // Split the data into separate values
    int colonIndex = data.indexOf(':');
    if (colonIndex != -1) {
      String dataType = data.substring(0, colonIndex);
      String sensorValueStr = data.substring(colonIndex + 1);
      float sensorValue = sensorValueStr.toFloat();
      // Send the sensor value to the corresponding virtual pin on Blynk
      if (dataType == "D") {
        Blynk.virtualWrite(V0, sensorValue);  // Distance
      } else if (dataType == "AQ") {
        Blynk.virtualWrite(V1, sensorValue);  // Air Quality
      } else if (dataType == "WL") {
        Blynk.virtualWrite(V2, sensorValue);  // Water Level
      } else if (dataType == "FD") {
        Blynk.virtualWrite(V3, sensorValue);  // Flame Detected
      } else if (dataType == "LI") {
        Blynk.virtualWrite(V4, sensorValue);  // Light Intensity
      } else if (dataType == "T") {
        Blynk.virtualWrite(V5, sensorValue);  // Temperature
      } else if (dataType == "H") {
        Blynk.virtualWrite(V6, sensorValue);  // Humidity
@haitembbs Please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
I would also recommend that you edit the title of your topic to make it much shorter, and spend some time explaining within your post what your issue/question is.
What exactly is your question?
Also, why are you doing this…
