Dear Blynk Team
i am using Blynk iot
when i was share my project with others there is a billing option i do want to show that Billing options with my customers there is any option inside the cloud ?
Hello. This problem is already fixed. In the next 24 hours, we’ll do the deployment with a fix. After which only admins will have the permission “Billing” which will hide this menu.
Dear sir
thanks for your prompet Reply that option was still there i allready logout and login couple of times.
@Huzefamaz1 do you use ios or Android? What app version? Please make sure you’re using the latest app version.
Dear sir
i am using Android i will attached here my mobile model for your refrence.
WhatsApp Image 2021-07-13 at 9.25.05 AM|225x500
I mean Blynk app version
It looks like some cache. The latest version was published 10 July
Try to force close the google play and reopen it.
Dear sir
Thank you sir ok never mind sir I will try on nextweek if still same I will text you here thank you sir
I have the same issue on my phone. Open/close google play multiple times helped.
