I made a blynk server on my ubuntu server, it happens to me that I am wanting to put some sensors, but I just put two sensors and it drops all the time I don’t know if the code is wrong or is something from my server I have the wrong code for the reconnection…
#include <DHT.h>
LiquidCrystal_I2C lcd(0x27,20,4);
#include <OneWire.h>
#define ONE_WIRE_BUS D5 // DS18B20 on arduino pin2 corresponds to D4 on physical board "D4 pin on the ndoemcu Module"
char auth[] = "bJa4MaHmNr_YOrwoDS3lIBQUVJFazr-R";
char ssid[] = "Pablo y Maca 2.4";
char pass[] = "laputaclave";
#define DHTPIN D4
#define DHTTYPE DHT22
#define RelayPin D6
#define RelayPin2 D7
int ReCnctFlag; // Reconnection Flag
int ReCnctCount = 0; // Reconnection counter
int UpdateFrequency = 2000L;
DHT dht(DHTPIN, DHTTYPE);
DallasTemperature DS18B20(&oneWire);
float tempW;
float t,h;
WidgetLED led1(V11);
WidgetLED led2(V12);
WidgetLED led3(V13);
DS18B20.begin();
dht.begin();
delay(2250);
pinMode(RelayPin,OUTPUT);
digitalWrite(RelayPin,HIGH);
pinMode(RelayPin2,OUTPUT);
digitalWrite(RelayPin2,HIGH);
delay(100);
lcd.begin(20,4);
lcd.init();
lcd.backlight();
lcd.setCursor (2,1);
lcd.print ("Conectando ... ");
lcd.setCursor (3,2);
lcd.print (" Red Wifi ... ");
delay(200);
Blynk.begin(auth, ssid, pass, IPAddress(201,212,65,156), 8080);
while (Blynk.connect() == false)
// Wait until connected
lcd.clear ();
lcd.setCursor (0,0);
lcd.print ("Conectado con.. ");
lcd.setCursor (0,1);
lcd.print (ssid);
lcd.setCursor (0,3);
lcd.print("IP:");
lcd.print( WiFi.localIP() );
delay(3000);
lcd.clear();
lcd.setCursor (3,1);
lcd.print("Iniciando Grow");
lcd.setCursor (4,3);
lcd.print("LOS LUISES...");
delay(3000);
lcd.clear();
timer.setInterval(UpdateFrequency, Temperatura);
timer.setInterval(UpdateFrequency, Lcd);
timer.setInterval(UpdateFrequency, Estados);
BLYNK_CONNECTED() {
Serial.println("Cconnected");
ReCnctCount = 0;
void Temperatura () {
h = dht.readHumidity(); // Read humidity (percent)
t = dht.readTemperature(); // Read temperature as C
tempW = DS18B20.getTempCByIndex(0);
DS18B20.requestTemperatures();
Blynk.virtualWrite(V10, tempW); //virtual pin V3
Blynk.virtualWrite(V6, t);
Blynk.virtualWrite(V5, h);
if (isnan(h) || isnan(t)) {
return;
void Lcd () {
Temperatura();
lcd.setCursor(0,0);
lcd.print("Temp Tierra: ");
lcd.print(tempW);
lcd.print((char)223);
lcd.print("c");
lcd.setCursor(0,1);
lcd.print("Temp Int: ");
lcd.print(t);
lcd.print("c");
lcd.setCursor(0,2);
lcd.print("Hum Int: ");
lcd.print(h);
lcd.print("%");
void Estados () {
if (( t <= 27 ) && (h <= 62 )) {
led1.on();
led2.off();
led3.off();
else if (( t >= 28 and t < 29) && (h >= 71 and h < 80 )) {
led1.off();
led2.on();
led3.off();
else if (( t >= 29) && (h >= 80 )) {
led1.off();
led2.off();
led3.on();
if (Blynk.connected()) { // If connected run as normal
} else if (ReCnctFlag == 0) { // If NOT connected and not already trying to reconnect, set timer to try to reconnect in 30 seconds
ReCnctFlag = 1; // Set reconnection Flag
Serial.println("Starting reconnection timer in 30 seconds...");
timer.setTimeout(30000L, []() { // Lambda Reconnection Timer Function
ReCnctFlag = 0; // Reset reconnection Flag
ReCnctCount++; // Increment reconnection Counter
Serial.print("Attempting reconnection #");
Serial.println(ReCnctCount);
Blynk.connect(); // Try to reconnect to the server
}); // END Timer Function
