Hello
My account doesn’t login blynk after i haved change timezone from rtc in blynk app
My account : ahmad.ahmad.qw57@gmail.com
Please help me😭
Hello
Please help me😭
Please answe me
org.joda.time.IllegalFieldValueException: Value 0 for millisOfDay is not supported: Illegal instant due to time zone offset transition (daylight savings time ‘gap’): 2021-03-26T00:00:00.000 (Asia/Damascus)
at org.joda.time.chrono.ZonedChronology$ZonedDateTimeField.set(ZonedChronology.java:6)
at org.joda.time.DateTime.withMillisOfDay(DateTime.java:1)
at com.blynk.android.model.additional.Time.dayHours(Time.java:1)
at com.blynk.android.model.additional.Time.createTimeFromTZ(Time.java:3)
at com.blynk.android.widget.dashboard.n.j.e.i.E(TimeInputViewAdapter.java:3)
at com.blynk.android.widget.dashboard.n.j.e.i.C(TimeInputViewAdapter.java:5)
at com.blynk.android.widget.dashboard.n.h.m(ViewAdapter.java:5)
at com.blynk.android.widget.dashboard.n.h.e(ViewAdapter.java:2)
at com.blynk.android.widget.dashboard.n.h.f(ViewAdapter.java:1)
at com.blynk.android.widget.dashboard.DashboardLayout.B(DashboardLayout.java:9)
at com.blynk.android.widget.dashboard.DashboardLayout.r(DashboardLayout.java:11)
at com.blynk.android.widget.dashboard.DashboardLayout.L0(DashboardLayout.java:26)
at com.blynk.android.widget.dashboard.DashboardLayout.F0(DashboardLayout.java:7)
at com.blynk.android.widget.dashboard.DashboardLayout.onLayout(DashboardLayout.java:12)
at android.view.View.layout(View.java:22237)
at android.view.ViewGroup.layout(ViewGroup.java:6395)
at androidx.coordinatorlayout.widget.CoordinatorLayout.w(CoordinatorLayout.java:18)
at androidx.coordinatorlayout.widget.CoordinatorLayout.C(CoordinatorLayout.java:7)
at androidx.coordinatorlayout.widget.CoordinatorLayout.onLayout(CoordinatorLayout.java:8)
at cc.blynk.widget.a.j.a.onLayout(ProjectPage.java:1)
at h.v.a.b.onLayout(ViewPager.java:35)
at android.widget.RelativeLayout.onLayout(RelativeLayout.java:1103)
at android.widget.LinearLayout.setChildFrame(LinearLayout.java:1829)
at android.widget.LinearLayout.layoutVertical(LinearLayout.java:1673)
at android.widget.LinearLayout.onLayout(LinearLayout.java:1582)
at android.widget.FrameLayout.layoutChildren(FrameLayout.java:332)
at android.widget.FrameLayout.onLayout(FrameLayout.java:270)
at com.android.internal.policy.DecorView.onLayout(DecorView.java:812)
at android.view.ViewRootImpl.performLayout(ViewRootImpl.java:3319)
at android.view.ViewRootImpl.performTraversals(ViewRootImpl.java:2815)
at android.view.ViewRootImpl.doTraversal(ViewRootImpl.java:1888)
at android.view.ViewRootImpl$TraversalRunnable.run(ViewRootImpl.java:8043)
at android.view.Choreographer$CallbackRecord.run(Choreographer.java:969)
at android.view.Choreographer.doCallbacks(Choreographer.java:793)
at android.view.Choreographer.doFrame(Choreographer.java:728)
at android.view.Choreographer$FrameDisplayEventReceiver.run(Choreographer.java:954)
at android.os.Handler.handleCallback(Handler.java:914)
at android.os.Handler.dispatchMessage(Handler.java:100)
at android.os.Looper.loop(Looper.java:224)
at android.app.ActivityThread.main(ActivityThread.java:7551)
at java.lang.reflect.Method.invoke(Native Method)
at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:539)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:995)
Caused by: org.joda.time.IllegalInstantException: Illegal instant due to time zone offset transition (daylight savings time ‘gap’): 2021-03-26T00:00:00.000 (Asia/Damascus)
at org.joda.time.chrono.ZonedChronology$ZonedDateTimeField.set(ZonedChronology.java:5)
… 75 more
HI, we are preparing a bugfix build for Play Store.
Thanx
But when abigfix on play?
It depends on google review, as quick workaround - change date on smartphone to yesterday or some other date, you can reset time input if needed and change date back.
The new build is uploaded to Play Store - should be soon available (it depends on Play Store review duration).
