Even running the following script for testing I can’t register the value from the app button at every cycle but it seems like value from the button in app is synced changes after a random interval of time.
#define TINY_GSM_MODEM_SIM800
#include <BlynkSimpleSIM800.h>
char auth[] = "xxxxx";
// Your GPRS credentials
// Leave empty, if missing user or pass
char apn[] = "apn.fastweb.it";
char user[] = "";
char pass[] = "";
int Valore_attivazione_antifurto;
SoftwareSerial SerialAT(10, 2); // TX, RX
TinyGsm modem(SerialAT);
BLYNK_CONNECTED() {
Blynk.syncVirtual(V2);
BLYNK_WRITE(V2)
Valore_attivazione_antifurto = param.asInt(); // assigning incoming value from pin V2 to a variable
Serial.print("Il valore del tasto di accensione è: : ");
Serial.println(Valore_attivazione_antifurto);
Serial.println();
// process received value
while (! Serial);
SerialAT.begin(9600);
delay(3000);
//BLYNK MODEM
modem.init();
///////////////////////////////////////// LOOP ///////////////////////////////////////////////
Serial.println("cycle");
delay(5000);
Thank you all for the quick replay. I think the code should be fine now. I’m including part of it in the post.
I now call blynk.run only once every cycle and run the cycle every 15 seconds. there are no more delays in the loop function.
void setup(){
while (! Serial);
Serial.println(F("Initializing FONA... (May take a few seconds)"));
delay(3000);
Serial.println(F("FONA OK"));
Serial.println(F("Enabling GPS..."));
fona.enableGPS(true);
delay(3000);
modem.init();
timer.setInterval(15000L, ciclo_antifurto);
///////////////////////////////// FUNZIONE DA CICLARE OGNI TIME INTERVAL ////////////////
void ciclo_antifurto() {
if (accel_on == 1 && Valore_attivazione_antifurto == 1)
{ //inizio a far funzionare SOLO l'accelerometro
Serial.println("L'antifurto è in funzione: controllo se la bici viene spostata");
accelerometro();
else if (accel_on == 0 && Valore_attivazione_antifurto == 1)
tracciamento();
else {
antifurto_spento();
///////////////////////////////////////////// FUNZIONI DEL LOOP /////////////////////////////////////////////////////
void accelerometro() {
if (count > 2 ) {
accel_on = 0;
Blynk.notify("ti hanno rubato la bici"); // funzione notifica push
Serial.println();
Serial.println("BIKE STOLEN");
Serial.println();
//////////////////////////// GPS ///////////////////////////////
void tracciamento () {
Serial.println ("Tracciamento della bici con GPS");
float latitude, longitude;
boolean gps_success = fona.getGPS(&latitude, &longitude);
if (gps_success) {
// enable NTP time sync
if (!fona.enableNTPTimeSync(true, F("pool.ntp.org"))) //
Serial.println(F("Failed to enable"));
// read the time
char buffer[23];
fona.getTime(buffer, 23); // make sure replybuffer is at least 23 bytes!
Serial.print(F("Time = "));
Serial.println(buffer);
int index = 0;
char modalit[] = "GPS"; // verra' visualizzato per comunicare se il pin messo in mappa mostra coordinate gps o gsm
myMap.location(index, latitude, longitude, buffer);
Blynk.virtualWrite(V4, modalit);
