Add details :
• Blynk Library version
• Add your sketch code. Code should be formatted as example below.
Hello , i have an issue with my project , i am using node mcu and just want to blink built in led on it using blynk app , i created a simple app but the problem is i did not received auth token in my email or the auth token received but after a while and then the message “not online yet” always appear in the app . my internet connection is good . this problem appear just in my work internet but in my home internet every thing is good.
Thanks for your answer , actually we don’t have IT department we are a small business but i can log to the router and fix the problem if you give me more details about problem fixing sir . thank you
If you have a simple domestic/SOHO system then it will be your ISP that is blocking the traffic. You could try talking to them, but ultimately I think you may need to change ISP.
This will give you more insight into the issue…
