I am getting a NaN return and i don't know why
Hey all
So i am using blynk to monitor a temp/humidity sensor that was built for me. I am a little familiar with working with Arduino stuff, but i am not super experienced so i apologize if this is a dumb question.
Once connected, the sensor array works well, but at ~12 hours after connecting, i get a NaN reading on my Blynk GUI. On the advice of a more technical friend, i inseted the following line into the code:
    float h = dht.readHumidity();
    delay(200);
    // fahrenheit = t * 1.8 + 32.0;
    if (t == NAN){
      Blynk.email("EMAILADDRESS", "ALARM", "Temp is NaN");
    if (h == NAN){
      Blynk.email("EMAILADDRESS", "ALARM", "Humid is NaN");
If i understand this correctly, i should get an “ALARM” email if the board gets a NaN. I received no email. The lads at Contact Blynk said i would only get a NaN from the sensors themselves. Can anyone help me out? Thanks in advance.
Here follows the code flashed to the device in its entirety:
    // display blynk information on serial monitor output
    // set up esp, blynk, dht and timer libraries
    char auth[] = "authcode"; //insert here your token generated by Blynk
    #include <DHT.h>
    #define DHTPIN 14  //dht22 data in
    #define DHTTYPE DHT22
    DHT dht(DHTPIN, DHTTYPE);
    float humidity, temp_f; // Values read from sensor
    // create a function called "sendData" and repeat it every x minutes, refer to line 162
    void sendData(){
        delay(200);
        if (t == NAN){
          Blynk.email("email", "ALARM", "Temp is NaN");
        if (h == NAN){
          Blynk.email("email", "ALARM", "Humid is NaN");
        Blynk.virtualWrite(11, h);
        delay(200);
        Blynk.virtualWrite(10, t);
        delay(300);
        // Blynk.virtualWrite(12, fahrenheit);
        // delay(300);
        // blink green LED on/off after upload to blynk server
        digitalWrite(5, HIGH);
        delay(300);
        digitalWrite(5, LOW);
        delay(300);
        delay(300);
        delay(300);
     delay(200);
      // print on serial monitor temp and humid values
        Serial.print("temperature C");
        Serial.println( t );
        delay(500);
        Serial.print("humidity %");
        Serial.println( h );
     delay(500);
      // checking for too lows and highs
      // email if necessary
      // blink the yellow alarm led if necessary
      if (t < 5){
      Blynk.email("email", "ALARM", "Temp is below 5C");
        digitalWrite(4, HIGH);
        delay(300);
        digitalWrite(4, LOW);
        delay(300);
      if (t > 40){
      Blynk.email("email", "ALARM", "Temp is above 40C");
        delay(300);
        delay(300);
        if (h < 20){
        Blynk.email("email", "ALARM", "Humid is below 20%");
        delay(300);
        delay(300);
       if (h > 90){
        Blynk.email("email", "ALARM", "Humid is above 90%");
        delay(300);
        delay(300);
    void setup(){
      dht.begin();
      pinMode(4, OUTPUT);   //yellow LED to test power
        delay(300);
        delay(300);
        delay(300);
        delay(300);
        delay(300);
        delay(300);
      pinMode(5, OUTPUT);   //green LED for online
        delay(300);
        delay(300);
        delay(300);
        delay(300);
        delay(300);
    delay(500);
      Blynk.begin(auth, "SSID,pw"); //insert here your SSID and password
    delay(500);
      Serial.print("device alive, go  to phone app");
        delay(300);
        delay(300);
        delay(300);
        delay(300);
        delay(300);
        delay(300);
    delay(500);
      // trigger sendData function above every x seconds
      timer.setInterval(10000, sendData);  // 10000 = 10 seconds  (x/1000=seconds)
    // everything is setup, now the system starts until power off
    void loop(){
you are using too many delays and they are long. It breaks connection to Blynk server. Please refer to Troubleshooting guide:
http://docs.blynk.cc/#troubleshooting-delay
Also, E-mails are limited to 1 per minute, so this code won’t work: [quote=“classicsnoot, post:1, topic:5611”]
if (t == NAN){
          Blynk.email("xxx@gmail.com", "ALARM", "Temp is NaN");
          Blynk.email("yyy@gmail.com", "ALARM", "Temp is NaN");
        if (h == NAN){
          Blynk.email("xxx@gmail.com", "ALARM", "Humid is NaN");
          Blynk.email("yyy@gmail.com", "ALARM", "Humid is NaN");
[/quote]
It is better to use
if (isnan(t)) {
Great! So shorten the delays i get, but what should i add to the email line to get it to work? Thanks for the help, Pavel. I really enjoy your services!
Solid copy. Thanks Dmitriy!
Overall there are many bugs in your code. I suggest you start simple and then complicate things.
First, make Timer work. Understand how to perform actions in intervals manner. Check the examples included in Blynk library ->>> PushData.ino. Then check the Email sketch.
Make sure it works - then add your own logic
