HW said connected, but server logs don't think so
• Hardware model + communication type.
Wemos d1 mini (latest lib 0.6.0) + local server server-0.41.2-java8.jar
Android 5.1
 Blynk.begin(auth, ssid, password, IPAddress(10,0,0,7), 8080);
t.every(15000, CheckConnection);
t.every(10000, pushData);
void CheckConnection(){    // check every 15s if connected to Blynk server
  if(!Blynk.connected()){
    Serial.println("Not connected to Blynk server");
    //Blynk.connect();  // try to connect to server with default timeout
  else{
    Serial.println("Connected to Blynk server");
void pushData() {
  Blynk.virtualWrite(V4, sppm);
 t.update();
 delay(100);
so time to time, after few hours working good, HW loose connection to server,
but serial port said: connected
I tried connect and auth
but with no luck
looks like Blynk.connected() don’t work properly
This clearly isn’t your full code, and the snippet that you have shared has issues - like no opening curly brackets in your void loop.
I doubt that people will take time to look at it in more detail, and maybe try it out for themselves, unless you post full code that hasn’t been hacked around in this way.
Also, your title talks about server logs, but in the post you talk only about serial monitor and you haven’t shared any server log info or said anything about what the online status of your device shows in the app.
#include <ESP8266mDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
#include <ESP8266HTTPClient.h>
#include <PubSubClient.h>
#include "Timer.h"
#include "MQ135.h"
#include <Wire.h>
#include "HTU21D.h"
// ==================================== VARS ==================================
//Create an instance of the object
HTU21D myHumidity;
Timer t;
int LED = D4; // Wemos build in led
int val;// Defines a numeric variable val
float ppm, rzero, temp, humd;
int count = 0;
int i = 0, sppm = 0;
int appm[50];
#define LED_ON   digitalWrite(LED, 1)
#define LED_OFF  digitalWrite(LED, 0)
MQ135 gasSensor = MQ135(A0);
const char* ssid = "xxx";
const char* password = "xxx";
char auth[] = "xxxxxxxxxxxxxxxx";
const char *mqtt_server = "10.0.0.7";
const int mqtt_port = 1883;
const char *mqtt_user = "xxxxx";
const char *mqtt_pass = "xxxxxx";
WiFiClient espClient;
PubSubClient mqtt_client(espClient);
void callback(char* topic, byte* payload, unsigned int length) {
  Serial.print("Message arrived [");
  Serial.print(topic);
  Serial.print("] ");
  Serial.println();
  pinMode(LED, OUTPUT); // Definition LED as output interface
  // start serial port
  setup_wifi();
  ArduinoOTA.setHostname("air_sensor");
  ArduinoOTA.onStart([]() {
    Serial.println("Start");
  ArduinoOTA.onEnd([]() {
    Serial.println("\nEnd");
  ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
    Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
  ArduinoOTA.onError([](ota_error_t error) {
    Serial.printf("Error[%u]: ", error);
    if (error == OTA_AUTH_ERROR) Serial.println("Auth Failed");
    else if (error == OTA_BEGIN_ERROR) Serial.println("Begin Failed");
    else if (error == OTA_CONNECT_ERROR) Serial.println("Connect Failed");
    else if (error == OTA_RECEIVE_ERROR) Serial.println("Receive Failed");
    else if (error == OTA_END_ERROR) Serial.println("End Failed");
  ArduinoOTA.begin();
  Serial.println("Ready");
  Serial.print("IP address: ");
  mqtt_client.setServer(mqtt_server, 1883);
  mqtt_client.setCallback(callback);
  int tickEvent = t.every(3000, blynkLed);
  myHumidity.begin();
void mqtt_connect() {
    Serial.print("Attempting MQTT connection...");
    String clientId = "ESP8266_AIR-";
    clientId += String(random(0xffff), HEX);
    if (mqtt_client.connect(clientId.c_str(),mqtt_user, mqtt_pass)) {
      Serial.println("connected");
      mqtt_client.subscribe("air/mq135");
      Serial.print("failed, rc=");
      Serial.print(mqtt_client.state());
      Serial.println(" try again in 5 seconds");
      delay(100);
  else{
void reconnect() {
  // Loop until we're reconnected
void setup_wifi() {
  Serial.println();
  Serial.println(ssid);
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
    delay(500);
    Serial.print(".");
  randomSeed(micros());
  Serial.println("");
  Serial.println("IP address: ");
void blynkLed() {
  val = digitalRead(LED); // The digital interface is assigned a value of 3 to read val
  if (val == LOW)  {
    LED_ON;
    LED_OFF;
void pushData() {
  Serial.println(val);
  Serial.println(ppm);
  Serial.println(rzero);
  Blynk.virtualWrite(V3, val);
  Blynk.virtualWrite(V5, rzero);
  Blynk.virtualWrite(V6, temp);
  Blynk.virtualWrite(V7, humd);
int sort_desc(const void *cmp1, const void *cmp2)
  // Need to cast the void * to int *
  int a = *((int *)cmp1);
  int b = *((int *)cmp2);
  // The comparison
  return a > b ? -1 : (a < b ? 1 : 0);
  // A simpler, probably faster way:
  //return b - a;
  if (WiFi.status() != WL_CONNECTED) {
    setup_wifi();
   ArduinoOTA.handle();
  if (!mqtt_client.connected()) {
    mqtt_connect();
  mqtt_client.loop();
  humd = myHumidity.readHumidity();
  temp = myHumidity.readTemperature();
  //ppm = gasSensor.getPPM ();
  ppm = gasSensor.getCorrectedPPM(temp, humd);
   //Serial.println(rzero);
  val = analogRead(A0);
   //Serial.println(val);
   //Serial.println(ppm);
  rzero = gasSensor.getCorrectedRZero(temp, humd);
  appm[i]=ppm;
  i++;
  if (i > 49) {
    int appm_length = sizeof(appm) / sizeof(appm[0]);
    // qsort - last parameter is a function pointer to the sort function
    qsort(appm, appm_length, sizeof(appm[0]), sort_desc);
    sppm = appm[i/2];
    char buffer[7];
    dtostrf(sppm, 1, 0, buffer);
    mqtt_client.publish("room/air/mq135", buffer, true);
    dtostrf(temp, 1, 2, buffer);
    mqtt_client.publish("room/air/gy21_temp", buffer, true);
    dtostrf(humd, 1, 0, buffer);
    mqtt_client.publish("room/air/gy21_humd", buffer, true);
    i = 0;
    Serial.print("sorted ppm: ");
    Serial.println(sppm);
    Serial.println("");
    Serial.print(" Temperature:");
    Serial.print(temp, 1);
    Serial.print("C");
    Serial.print(" Humidity:");
    Serial.print(humd, 1);
    Serial.println("%");
 t.update();
 delay(100);
full code. Sensitive data masked by xxx
Serial log
 Temperature:21.4C Humidity:42.1%
141
1281.46
578.28
sorted ppm: 1556
 Temperature:21.4C Humidity:42.0%
150
1559.78
538.66
sorted ppm: 1558
1
1496.73
550.55
local blynk server log when this device connected
12:32:30.962 TRACE- Blynk hardware plain protocol connection detected.
12:32:30.963 TRACE- Incoming HardwareLoginMessage{LoginMessage{id=1, command=LoginHardware, body='xxxxxxxxxxxxxxxxxxxxx'}}
12:32:30.963 DEBUG- Re registering hard channel. [id: 0x4249fb21, L:/10.0.0.7:8080 - R:/10.0.0.88:56501]
12:32:30.964 DEBUG- completeLogin. [id: 0x4249fb21, L:/10.0.0.7:8080 - R:/10.0.0.88:56501]
12:32:30.965 TRACE- Connected device id 0, dash id 532157253
12:32:30.965 INFO - xxxxxxxxxxxx hardware joined.
12:32:31.036 TRACE- Incoming id=2, command=Internal, body='ver0.6.0h-beat10buff-in1024devESP8266buildFeb 12 2019 20:54:39'
12:32:31.037 TRACE- Info command. heartbeat interval 10
12:32:32.460 TRACE- Incoming id=27, command=GetDevices, body='532157253'
12:32:38.205 TRACE- Incoming id=38, command=Ping, body=''
when not connected there is nothing about this device in server log
time to time have errors like this:
12:33:40.017 TRACE- Blynk server IOException.
io.netty.channel.unix.Errors$NativeIoException: syscall:read(..) failed: Connection reset by peer
        at io.netty.channel.unix.FileDescriptor.readAddress(..)(Unknown Source) ~[server-0.41.2-java8.jar:?]
12:33:40.780 TRACE- Incoming id=18, command=Ping, body=''
12:33:41.680 TRACE- Incoming id=40, command=Ping, body=''
but it happened every minute
That’s quite a void loop you’ve got there - taking humidity, temperature and gas reading on every cycle through the loop.
Not surprising that you’re getting disconnections.
Don’t understand you. What wrong with this loop ?
Why you think taking this params affect connection to blynk ?
Timers working well, as you can see, every 15 sec, I check connection with blynk server
CheckConnection(), and it return “Connected to Blynk server”
But this is not true.
How do you think should I fix it ?
Read this:
http://help.blynk.cc/getting-started-library-auth-token-code-examples/blynk-basics/keep-your-void-loop-clean
Thank you, will try all recommendations from.
