I am developing a weather station with an ESP32 and Blynk and everything is working fine. Now I am trying to use a SIM800L for remote areas and after some problems like having to put a step up to power it with 4 volts and some issues learning how to use it, it is working with Blynk. However I also need to get an API request using HTTP to get the local timezone to handle the correct local time in my GPS and although it is working fine on Wifi, I cannot put it to work on SIM800L despite numerous attempts and reading the docs.
Here is the relevant code, I have two functions to parse the API one for WiFi getTimeZoneOffset() and the other for SIM800L which I am using right now getTimeZoneOffsetSim800l()
Here is the console output
response=
ERROR
+CIPRXGET: 1,0
OK
OK
OK
Error on HTTP request
Also just out of curiosity I would like to know if it is possible to use Blynk.AIR and Edgent with SIM800L, or is it a bad idea?
#define BLYNK_TEMPLATE_ID "XXXXXXXXXXX"
#define BLYNK_TEMPLATE_NAME "YYYYYYYYYY"
#define BLYNK_AUTH_TOKEN "ZZZZZZZZZ"
// Select your modem:
#define TINY_GSM_MODEM_SIM800
#include <TinyGsmClient.h>
#include "DHT.h"
#include <numeric>
#include <HTTPClient.h>
#include <Adafruit_BMP280.h>
#include <Adafruit_MLX90614.h>
#include "riodejaneiro_openweather.h"
#include "SPIFFS.h"
#include <deque>
#include <TinyGPSPlus.h>
#include <ArduinoJson.h>
// Set serial for debug console (to the Serial Monitor, default speed 115200)
#define SerialMon Serial
#define SerialAT Serial1
#define RXD1 9
#define TXD1 10
// Your GPRS credentials, if any
const char apn[] = "claro.com.br";
const char user[] = "claro";
const char pass[] = "claro";
const char auth[] = "XXXXXXXXXXXXXXXXXXXX";
// Global state variables
struct GPSState {
double longitude, latitude;
int currentHour, currentMonth;
String season;
String gps_time;
} gpsstate;
// Global strings
struct GlobalStrings {
String message;
String apiKey = "XXXXXXXXX";
} globalStrings;
int timerId1;
// Create sensor instances
Adafruit_BMP280 bmp; // For the BMP280 sensor
DHT dht(DHTPIN, DHTTYPE); // For the DHT sensor
Adafruit_MLX90614 mlx = Adafruit_MLX90614(); // For the MLX90614 sensor
TinyGPSPlus gps; // For the GPS module
BlynkTimer timer; // For Blynk timer
TinyGsm modem(SerialAT);
// Set console baud rate
SerialMon.begin(115200);
// Set GSM module baud rate
SerialAT.begin(115200);
delay(6000);
SerialMon.println("Initializing modem...");
modem.restart();
String modemInfo = modem.getModemInfo();
SerialMon.print("Modem Info: ");
SerialMon.println(modemInfo);
// Check if modemInfo is empty or null
if (modemInfo == NULL || modemInfo.length() == 0) {
SerialMon.println("No modem info, restarting modem...");
// Power off the modem
modem.poweroff();
delay(10000); // Wait for some time (10 seconds)
// Try getting the modem information again
SerialMon.print("Modem Info after restart: ");
// Unlock your SIM card with a PIN
//modem.simUnlock("1234");
Serial2.begin(9600, SERIAL_8N1, RXD2, TXD2);
timerId1 = timer.setInterval(10 * 1000L, takeMeasurements);
// Initialize sensors and buffers
initializeSensors();
// Update the dataset interval to 3 hours (180 minutes)
settings.updateDatasetInterval(180);
// Initialize maxEntries based on the smallest interval
// Use the timeData instance to access intervals
timeData.maxEntries = 3600000 / timeData.intervals[0]; // Max entries for 1 hour based on the smallest interval
// Load previous measurements into the buffers
loadMeasurementsAndInitializeBuffers();
// Function to get the timezone offset in seconds
long getTimeZoneOffset() {
HTTPClient http;
// Use the latitude and longitude from the 'state' struct
String apiEndpoint = "http://api.timezonedb.com/v2.1/get-time-zone?key=" + globalStrings.apiKey +
"&format=json&by=position&lat=" + String(gpsstate.latitude) +
"&lng=" + String(gpsstate.longitude);
http.begin(apiEndpoint);
int httpCode = http.GET();
if (httpCode == 200) { // If the call to the API was successful
String payload = http.getString();
DynamicJsonDocument doc(1024);
deserializeJson(doc, payload);
if (doc["status"] == "OK") {
long gmtOffset = doc["gmtOffset"]; // Get the GMT offset in seconds
http.end();
return gmtOffset;
Serial.println("API returned an error: " + String(doc["message"].as<const char*>()));
http.end();
return 0;
Serial.println("Error on HTTP request");
http.end();
return 0;
long getTimeZoneOffsetSim800l() {
// Initialize HTTP service
SerialAT.println("AT+HTTPINIT");
// Set HTTP parameters
"&format=json&by=position&lat=" + String(gpsstate.latitude, 2) +
"&lng=" + String(gpsstate.longitude, 2) + "&fields=gmtOffset";
SerialAT.println("AT+HTTPPARA=\"URL\",\"" + apiEndpoint + "\"\r\n");
// Start HTTP GET session
SerialAT.println("AT+HTTPACTION=0");
// Read the response
SerialAT.println("AT+HTTPREAD");
String response = "";
while (SerialAT.available()) {
response += char(SerialAT.read());
Serial.println("response=");
Serial.println(response);
// Parse response if HTTP request was successful
if (response.indexOf("+HTTPACTION: 0,200") != -1) {
int jsonStart = response.indexOf('{');
int jsonEnd = response.lastIndexOf('}');
if (jsonStart != -1 && jsonEnd != -1) {
String jsonResponse = response.substring(jsonStart, jsonEnd + 1);
deserializeJson(doc, jsonResponse);
return gmtOffset;
return 0;
return 0;
// Terminate HTTP service
SerialAT.println("AT+HTTPTERM");
