IF you don’t have a Raspberry PI to install Mosquitto broker and need an MQTT that works with BLYNK here is the cheapest and easiest solution.
The “ESP uMQTT Broker”
MQTT Broker/Bridge on the ESP8266
the CODE works on any ESP8266 NodeMCU, Wemo D1 ,Sonoff Basic (Tested)
// uMQTTBroker for Sonoff
// The program simply starts a broker and waits for any client to connect.
// maximal 10 Client possible
#include "ESP8266WiFi.h"
#include "uMQTTBroker.h"
#include "espconn.h"
// Your WiFi config here //////////////////////////////////////////////////////
char host[] = "ESP-MQTT"; // Hostname
char ssid[] = "ssid"; // your network SSID (name)
char pass[] = "password"; // your network password
bool STATIC = false; // Static IP for STA Mode? [false/true]
IPAddress ip(192,168,1,200); // Static IP
IPAddress gw(192,168,1,1); // Gateway
IPAddress su(255,255,255,0); // Subnet
bool WiFiAP = false; // Do yo want the ESP as AP? [false/true]
bool EXAMPL = true; // Example Progamm on/off? [false/true]
// Example need rule in Test_1
// rule1 on power1#state=1 do publish stat/TEST_1/POWER TRUE endon on power1#state=0 do publish stat/TEST_1/POWER FALSE endon
// Declare Variable ///////////////////////////////////////////////////////////
String RECEIVE; // Received Topic for logical operations
String RECEVAL; // Received Topic for logical operations
int GPIO0 = 0; // GPIO0 -> Sonoff Basic - Button
int GPIO12 = 12; // GPIO12 -> Sonoff Basic - Relais
int GPIO13 = 13; // GPIO13 -> Sonoff Basic - green LED
int GPIO14 = 14; // GPIO14 -> Sonoff Basic - Optional Sensor
int BSTAT1; // State Button GPIO0
int RSTAT1; // State Relais GPIO12
int TRIGG1 = LOW;
class myMQTTBroker: public uMQTTBroker
public:
virtual bool onConnect(IPAddress addr, uint16_t client_count) {
Serial.println(addr.toString()+" connected");
return true;
virtual bool onAuth(String MQTTUSER, String MQTTPASS) {
Serial.println("Username/Password: "+MQTTUSER+"/"+MQTTPASS);
return true;
virtual void onData(String topic, const char *data, uint32_t length) {
char data_chr[length+1];
os_memcpy(data_chr, data, length);
data_chr[length] = '\0';
String data_str = (String)data_chr;
data_str.toUpperCase();
RECEVAL = topic+" "+data_str;
Serial.println("received: "+RECEVAL);
void MQTT_Server_cleanupClientCons();
myMQTTBroker myBroker;
// WiFi init stuff ////////////////////////////////////////////////////////////
void startWiFiClient()
if (STATIC) {
WiFi.config(ip, gw, gw, su);
WiFi.softAPdisconnect(true);
WiFi.hostname(host);
Serial.println("Connecting to "+(String)ssid);
WiFi.begin(ssid, pass);
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: " + WiFi.localIP().toString());
void startWiFiAP()
WiFi.softAP(ssid, pass);
Serial.println("AP started");
Serial.println("IP address: " + WiFi.softAPIP().toString());
// Configure GPIO //////////////////////////////////////////////////////////
pinMode(GPIO0, INPUT_PULLUP);
pinMode(GPIO12, OUTPUT);
pinMode(GPIO13, OUTPUT);
pinMode(GPIO14, OUTPUT);
// Serial Interface
Serial.println();
Serial.println();
// Start WiFi
espconn_tcp_set_max_con(10);
if (WiFiAP) {
startWiFiAP();
startWiFiClient();
// Start the broker
Serial.println("Starting MQTT broker");
myBroker.init();
// Subscribe to anything ////////////////////////////////////////////////////
myBroker.subscribe("#");
RECEIVE = RECEVAL;
// Example Programm /////////////////////////////////////////////////////////
if (EXAMPL) {
if (RECEIVE.equals("stat/TEST_1/POWER FALSE")) {
myBroker.publish("cmnd/TEST_2/POWER", "ON");
if (RECEIVE.equals("stat/TEST_1/POWER TRUE")) {
myBroker.publish("cmnd/TEST_2/POWER", "OFF");
if (RECEIVE.equals("cmnd/"+(String)host+"/STATUS 1")) {
myBroker.publish("cmnd/TEST_1/POWER", "(null)");
myBroker.publish("cmnd/TEST_2/POWER", "(null)");
if (RSTAT1 == LOW) {
myBroker.publish("stat/"+(String)host+"/POWER", "OFF");
myBroker.publish("stat/"+(String)host+"/POWER", "ON");
// Basic Function Button/MQTT ///////////////////////////////////////////////
BSTAT1 = digitalRead(GPIO0);
RSTAT1 = digitalRead(GPIO12);
// Button event /////////////////////////////////////////////////////////////
if (BSTAT1 == LOW and RSTAT1 == LOW and TRIGG1 == LOW) {
digitalWrite(GPIO12, HIGH);
TRIGG1 = HIGH;
Serial.println("GPIO0 POWER ON");
if (BSTAT1 == LOW and RSTAT1 == HIGH and TRIGG1 == LOW) {
digitalWrite(GPIO12, LOW);
TRIGG1 = HIGH;
Serial.println("GPIO0 POWER OFF");
if (BSTAT1 == HIGH) { TRIGG1 = LOW; }
// MQTT event ///////////////////////////////////////////////////////////////
if (RECEIVE.equals("cmnd/"+(String)host+"/POWER ON")) {
Serial.println("stat/"+(String)host+"/POWER ON");
delay(50);
if (RECEIVE.equals("cmnd/"+(String)host+"/POWER OFF")) {
Serial.println("stat/"+(String)host+"/POWER OFF");
delay(50);
if (RECEIVE.equals("cmnd/"+(String)host+"/POWER ")) {
// LED STATUS ///////////////////////////////////////////////////////////////
digitalWrite(GPIO13, HIGH);
digitalWrite(GPIO13, LOW);
- martin-ger uMQTTBroker & esp_mqtt
you can test it with
IoT MQTT Dashboard
https://play.google.com/store/apps/details?id=com.thn.iotmqttdashboard
I even test “uMQTT broker” with HA and it works OK
MQTT-Explorer for Windows
