How To Use Physical Switches also Along With App
I would like to control my appliances with Physical Switches Along with Blynk.
To do so I am using the code given below.
 #include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#define DEBUG_SW 0
#define S1 32
#define R1 15
#define S2 35
#define R2 2
#define S3 34
#define R3 4
#define S4 39
#define R4 22
#define LED1 26
#define LED2 25
#define LED3 27
#define Buzzer 21
int MODE = 0;
char ssid[] = "SSID";
char pass[] = "PASS";
char auth[] = "AUTH TOKEN";
int switch_ON_Flag1_previous_I = 0;
int switch_ON_Flag2_previous_I = 0;
int switch_ON_Flag3_previous_I = 0;
int switch_ON_Flag4_previous_I = 0;
BLYNK_WRITE(V1)
  digitalWrite(R1, pinValue);
  // process received value
BLYNK_WRITE(V2)
  int pinValue = param.asInt(); // assigning incoming value from pin V2 to a variable
  digitalWrite(R2, pinValue);
BLYNK_WRITE(V3)
  int pinValue = param.asInt(); // assigning incoming value from pin V3 to a variable
  digitalWrite(R3, pinValue);
BLYNK_WRITE(V4)
  int pinValue = param.asInt(); // assigning incoming value from pin V4 to a variable
  digitalWrite(R4, pinValue);
void with_internet()
  if (digitalRead(S1) == LOW)
    if (switch_ON_Flag1_previous_I == 0 )
      digitalWrite(R1, LOW);
      if (DEBUG_SW) Serial.println("Relay1- ON");
      Blynk.virtualWrite(V1, 0);
      switch_ON_Flag1_previous_I = 1;
    if (DEBUG_SW) Serial.println("Switch1 -ON");
  if (digitalRead(S1) == HIGH )
    if (switch_ON_Flag1_previous_I == 1)
      digitalWrite(R1, HIGH);
      if (DEBUG_SW) Serial.println("Relay1 OFF");
      Blynk.virtualWrite(V1, 1);
    if (DEBUG_SW)Serial.println("Switch1 OFF");
  if (digitalRead(S2) == LOW)
    if (switch_ON_Flag2_previous_I == 0 )
      digitalWrite(R2, LOW);
      if (DEBUG_SW)  Serial.println("Relay2- ON");
      Blynk.virtualWrite(V2, 0);
      switch_ON_Flag2_previous_I = 1;
    if (DEBUG_SW) Serial.println("Switch2 -ON");
  if (digitalRead(S2) == HIGH )
    if (switch_ON_Flag2_previous_I == 1)
      digitalWrite(R2, HIGH);
      if (DEBUG_SW) Serial.println("Relay2 OFF");
      Blynk.virtualWrite(V2, 1);
    if (DEBUG_SW)Serial.println("Switch2 OFF");
    //delay(200);
  if (digitalRead(S3) == LOW)
    if (switch_ON_Flag3_previous_I == 0 )
      digitalWrite(R3, LOW);
      if (DEBUG_SW) Serial.println("Relay3- ON");
      Blynk.virtualWrite(V3, 0);
      switch_ON_Flag3_previous_I = 1;
    if (DEBUG_SW) Serial.println("Switch3 -ON");
  if (digitalRead(S3) == HIGH )
    if (switch_ON_Flag3_previous_I == 1)
      digitalWrite(R3, HIGH);
      if (DEBUG_SW) Serial.println("Relay3 OFF");
      Blynk.virtualWrite(V3, 1);
    if (DEBUG_SW)Serial.println("Switch3 OFF");
    //delay(200);
  if (digitalRead(S4) == LOW)
    if (switch_ON_Flag4_previous_I == 0 )
      digitalWrite(R4, LOW);
      if (DEBUG_SW) Serial.println("Relay4- ON");
      Blynk.virtualWrite(V4, 0);
      switch_ON_Flag4_previous_I = 1;
    if (DEBUG_SW) Serial.println("Switch4 -ON");
  if (digitalRead(S4) == HIGH )
    if (switch_ON_Flag4_previous_I == 1)
      digitalWrite(R4, HIGH);
      if (DEBUG_SW) Serial.println("Relay4 OFF");
      Blynk.virtualWrite(V4, 1);
    if (DEBUG_SW)Serial.println("Switch4 OFF");
    //delay(200);
void without_internet()
  digitalWrite(R1, digitalRead(S1));
  digitalWrite(R2, digitalRead(S2));
  digitalWrite(R3, digitalRead(S3));
  digitalWrite(R4, digitalRead(S4));
void checkBlynk() { // called every 3 seconds by SimpleTimer
  bool isconnected = Blynk.connected();
  if (isconnected == false) {
    MODE = 1;
    digitalWrite(LED1, HIGH);
    digitalWrite(LED2, LOW);
    digitalWrite(LED3, LOW);
  if (isconnected == true) {
    MODE = 0;
    digitalWrite(LED2, HIGH);
    digitalWrite(LED3, HIGH);
  if (DEBUG_SW) Serial.begin(9600);
  pinMode(S1, INPUT);
  pinMode(R1, OUTPUT);
  pinMode(S2, INPUT);
  pinMode(R2, OUTPUT);
  pinMode(S3, INPUT);
  pinMode(R3, OUTPUT);
  pinMode(S4, INPUT);
  pinMode(R4, OUTPUT);
  pinMode(LED1, OUTPUT);
  pinMode(LED2, OUTPUT);
  pinMode(LED3, OUTPUT);
  pinMode(Buzzer, OUTPUT);
  delay(200);
  delay(200);
  delay(200);
  digitalWrite(LED1, LOW);
  delay(500);
  delay(200);
  delay(200);
  delay(200);
  //pinMode(MODE, INPUT);
  WiFi.begin(ssid, pass);
  timer.setInterval(3000L, checkBlynk); // check if connected to Blynk server every 3 seconds
  Blynk.config(auth);//, ssid, pass);
  if (WiFi.status() != WL_CONNECTED)
    if (DEBUG_SW) Serial.println("Not Connected");
    if (DEBUG_SW) Serial.println(" Connected");
  if (MODE == 0)
    with_internet();
    without_internet();
I am connecting the circuit diagram as per the image given below in the link.
Google Photos
This is not working.
What is the reason for it and how can I solve it?
Thanks for help in advance.
PS: I am not connecting the buzzers and indicator LED s for now.
What exactly does that mean?
Is the whole circuit dead, or are some aspects of the functionality working and other aspects not?
The physical switches are not working. Everything else are working properly.
I can’t find out why. It may be due to code also.
And what do you see in your serial monitor when you set your DEBUG_SW to 1 and operate your switches?
Why not ask the author of the project?
If Debug_sw is 1 it’s printing the the status of the switches infinite times. And founding l giving garbage value if it’s 0.
No reply
What happens if you disconnect everything from the board, except the power/USB connector and the physical switches and pull-up resistors?
I want to eliminate power/load/EMF issues so want the NodeMCU powered directly from the PC via USB.
Removed the resistor and power with USB from PC still no help.
That’s not what I suggested that you do.
I suspect that the “garbage” you get when the switch value is LOW is actually a reboot message from the ESP32 If you used the native baud rate of the ESP32 (usually 74880 or 115200) then the message wouldn’t be garbage.
I have a feeling that energising the relays may be pulling the supply voltage down to a level that causes the MCU to reboot.
