Yep i am aware of it… If we go as per the safe pins we get only 2 pins (and few which spikes during boot.)
But the pins what i am using as of now works just fine while using push buttons. May be keeping few pins high during boot will destroy the module.
Look out the code:
#include <ESP8266mDNS.h> // For OTA with ESP8266
#include <WiFiUdp.h> // For OTA
#include <ArduinoOTA.h> // For OTA
void checkPhysicalButton();
int relay1State = LOW;
int Button1State = HIGH;
int relay2State = LOW;
int Button2State = HIGH;
int relay3State = LOW;
int Button3State = HIGH;
int relay4State = LOW;
int Button4State = HIGH;
#define AUTH "AUTH" // You should get Auth Token in the Blynk App.
#define WIFI_SSID "SSID" //Enter Wifi Name
#define WIFI_PASS "PASS" //Enter wifi Password
#define SERVER "blynk-cloud.com " // Comment-out if use Blynk hosted cloud service
#define PORT 8442
#define RELAY_PIN_1 5 //D1
#define RELAY_PIN_2 4 //D2
#define RELAY_PIN_3 12 //D6
#define RELAY_PIN_4 13 //D7
#define BUTTON_1 0 //D3
#define BUTTON_2 14 //D5
#define BUTTON_3 2 //D4
#define BUTTON_4 15 //D8
#define VPIN_BUTTON_1 V12
#define VPIN_BUTTON_2 V13
#define VPIN_BUTTON_3 V14
#define VPIN_BUTTON_4 V15
int oldState1 = HIGH;
int oldState2 = HIGH;
int oldState3 = HIGH;
int oldState4 = HIGH;
#define OTA_HOSTNAME "Home_Automation"
BLYNK_CONNECTED() {
Blynk.syncVirtual(VPIN_BUTTON_1);
Blynk.syncVirtual(VPIN_BUTTON_2);
Blynk.syncVirtual(VPIN_BUTTON_3);
Blynk.syncVirtual(VPIN_BUTTON_4);
// When App button is pushed - switch the state
BLYNK_WRITE(VPIN_BUTTON_1) {
relay1State = param.asInt();
digitalWrite(RELAY_PIN_1, relay1State);
BLYNK_WRITE(VPIN_BUTTON_2) {
relay2State = param.asInt();
digitalWrite(RELAY_PIN_2, relay2State);
BLYNK_WRITE(VPIN_BUTTON_3) {
relay3State = param.asInt();
digitalWrite(RELAY_PIN_3, relay3State);
BLYNK_WRITE(VPIN_BUTTON_4) {
relay4State = param.asInt();
digitalWrite(RELAY_PIN_4, relay4State);
int State1 = digitalRead(BUTTON_1); //"State" containes the logical level of the switch
if (State1 != oldState1) { //Change of the input state? Yes if I change the switch position
oldState1 = State1; //in order to be ready for a new change of state
relay1State = !relay1State;
Blynk.virtualWrite(VPIN_BUTTON_1, relay1State);
int State2 = digitalRead(BUTTON_2); //"State" containes the logical level of the switch
if (State2 != oldState2) { //Change of the input state? Yes if I change the switch position
oldState2 = State2; //in order to be ready for a new change of state
relay2State = !relay2State;
Blynk.virtualWrite(VPIN_BUTTON_2, relay2State);
int State3 = digitalRead(BUTTON_3); //"State" containes the logical level of the switch
if (State3 != oldState3) { //Change of the input state? Yes if I change the switch position
oldState3 = State3; //in order to be ready for a new change of state
relay3State = !relay3State;
Blynk.virtualWrite(VPIN_BUTTON_3, relay3State);
int State4 = digitalRead(BUTTON_4); //"State" containes the logical level of the switch
if (State4 != oldState4) { //Change of the input state? Yes if I change the switch position
oldState4 = State4; //in order to be ready for a new change of state
relay4State = !relay4State;
Blynk.virtualWrite(VPIN_BUTTON_4, relay4State);
Blynk.begin(AUTH, WIFI_SSID, WIFI_PASS,"blynk-cloud.com", 8442);
ArduinoOTA.setHostname(OTA_HOSTNAME); // For OTA - Use your own device identifying name
ArduinoOTA.begin(); // For OTA
pinMode(RELAY_PIN_1, OUTPUT);
pinMode(BUTTON_1, INPUT_PULLUP);
pinMode(RELAY_PIN_2, OUTPUT);
pinMode(BUTTON_2, INPUT_PULLUP);
pinMode(RELAY_PIN_3, OUTPUT);
pinMode(BUTTON_3, INPUT_PULLUP);
pinMode(RELAY_PIN_4, OUTPUT);
pinMode(BUTTON_4, INPUT_PULLUP);
// Setup a function to be called every 100 ms
timer.setInterval(100L, checkPhysicalButton);
ArduinoOTA.handle(); // For OTA
I guess this will be problem if the switch is connected to GND during boot. I will crash the ESP. Have you checked all the switches for all the position combination (UP / DOWN)… Because this will definitely crash during startup if pins are pulled low. And even D8 is ment to be pulled high during boot. I can see a button connected to D8, if the switch is on and if it is connected to GND then it will crash… Test this out…
