details :
• NodeMCU Esp8266, PIR Sensor, Buzzer
• Android, Windows 10
#define BLYNK_TEMPLATE_ID "xxxxxxxxxxxxxxxxxxx"
#define BLYNK_DEVICE_NAME "xxxxxxxxxxx"
#define BLYNK_AUTH_TOKEN "xxxxxxxxxxxxxxxxxxxxxxxxxxx"
#include <Wire.h>
#include <WiFiClientSecure.h>
#include <UniversalTelegramBot.h>
char ssid[] = "xxxxx";
char pass[] = "xxxxxxx";
BLYNK_WRITE();
#define BOTtoken "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
#define CHAT_ID "xxxxxxxxxxxxxxxxxxx"
#define Sensor D0
#define LEDR D3
#define LEDG D4
#define Buzzer D5
X509List cert(TELEGRAM_CERTIFICATE_ROOT);
WiFiClientSecure client;
UniversalTelegramBot bot(BOTtoken, client);
//lcd.init();
//lcd.backlight();
Wire.begin(D2, D1);
configTime(0, 0, "pool.ntp.org"); // get UTC time via NTP
client.setTrustAnchors(&cert); // Add root certificate for api.telegram.org
pinMode(Sensor, INPUT);
pinMode(LEDR, OUTPUT);
pinMode(LEDG, OUTPUT);
pinMode(Buzzer, OUTPUT);
int a = 0;
Serial.print(".");
//lcd.setCursor(a, 0);
//lcd.print(".");
delay(500);
a++;
Serial.println("");
//lcd.clear();
//lcd.setCursor(0, 0);
//lcd.print("WiFi connected");
Serial.print("IP address: ");
//lcd.setCursor(0, 1);
//lcd.print(WiFi.localIP());
delay(500);
bot.sendMessage(CHAT_ID, "System started", "");
//lcd.clear();
//lcd.print("System started");
//lcd.clear();
bool value = digitalRead(Sensor);
Serial.println(value);
if (value == 1) {
Serial.println("Motion Detected");
digitalWrite(LEDR, HIGH);
digitalWrite(Buzzer, HIGH);
digitalWrite(LEDG, LOW);
//lcd.print("Motion Detected");
bot.sendMessage(CHAT_ID, "MALING !!", "");
} else if (value == 0) {
digitalWrite(LEDR, LOW);
digitalWrite(Buzzer, LOW);
digitalWrite(LEDG, HIGH);
//lcd.print("No Motion ");
Blynk.run(V1);
