Automationlarımda bir kereden fazla tetikleme yapamıyorum.
Read this before creating new topic:
- Search forum for similar topics
- Check https://docs.blynk.io
- Add details :
• Hardware model + communication type. For example: ESP32
• Smartphone OS (iOS or Android) + OS version
• Blynk server region
• Blynk Library version
• Post your FORMATTED sketch code. Remove your AUTH TOKEN from code. Don’t post screenshots
• Post your serial monitor output when experiencing some issues
If you don’t format your code, your topic can be deleted by moderators.
Here is a correct example of code formatting:
//#define BLYNK_TEMPLATE_ID "TMPxxxxxx"
//#define BLYNK_TEMPLATE_NAME "Device"
#include "BlynkEdgent.h"
delay(100);
BlynkEdgent.begin();
BlynkEdgent.run();
