this tool calculates the time every two swings past the infrared sensor. like stopwatch that used to count time in simple pendulum experiment,
How do I display the data on the serial monitor to the LCD widget in the latest version of Blynk? already using blynk.virtualWrite but still can’t appear on the LCD widget in blynk
Ayunan means “number of swings”
waktu means “seconds”
@andikarifqi Please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
Okay, first of all, you shouldn’t run this sketch on your device, as it breaks the golden role of Blynk, which is never to have Blynk.virtualWrite commands in your void loop.
I’d suggest that you provide some clues about which virtual datastream your Blynk LCD widget is attached to, what data type you’ve chosen for that datastream, how you’ve configured that widget in your mobile dashboard, and whether you are using the iOS or Android version of the app.
i’m using blynk android version. the first line of LCD widget (ayunan) is attach to Virtual datastream 3, and the second line of LCD widget (waktu) is attach to Virtual datastrean1
You keep feeding partial answers through one piece at a time, as though the information is top secret. I’m not going to keep asking for the information over and over again, as I clearly don’t have a high enough security clearance for this information
i’m sorry im keep repeat the answer. (even tough i’ve share all the information as far as i know).I apologize for not being able to explain and provide understanding information about this project. Honestly, I myself am very confused how to convey all about my first project. thanks for the directions and sorry for my misunderstanding to have confused you.
