As I said earlier, this is not so easy as “Just forward those and those, and it will work with a snap of a finger”! Also any service like no-ip.com or dyndns will not work like magic, and thus does not solve everything.
I said:
You said:
But then you said:
So that looks like you does NOT meet the very first requirement, thus, it is a bit unclear, as how you are replying, so, we can try to test this again, so:
- Open start menu
- Search for “cmd”
- Open application “Command prompt”
- In the black window wich shold appear, write:
tracert 80.211.207.110 - The output copy and pase here as reply to this post, or just take screenshot of the output.
We will see if that helps, good luck.
