Well hello, internet,
I wanna use the menu in blynk, but I can’t. for example as a simple sketch:
When a user selects the 1st item it will blink an LED for a short duration, and when the 2nd item is selected it will blink the previous LED for a long duration.
Is this possible?
I’m using NODEMCU D1 mini
Thanks in advance.
Obviously it’s possible, but maybe not with your current skill set.
Take a look at this sketch:
https://examples.blynk.cc/?board=ESP8266&shield=ESP8266%20WiFi&example=Widgets%2FMenu
And do a google search for the Ticker library.
Combine the two and you’ll valve what you need, and you’ll have learned something along the way.
Thanks for your reply,
I’ve used the official menu sketch already to make what I described, but all in vain.
I intended to do something like goto or something else.
I’ll google the Ticker library, and get back to you as soon as possible.
Good luck with that!
I’ve never felt the need to use a goto in C++, although I guess there are cases where it is a valuable tool.
The problem I have with goto is that it reminds me too much of the awful GOTO statement in BASIC, which is something I haven’t felt the need to use for at least the past 35 years.
WOW 35 years at least!!!, Is it an annoying tool that you’ve been a long time don’t use it?
I’m a beginner at C language, so all I could really think of at that moment is goto.
There no need to direct your program flow anywhere, so go to or calling a function are unnecessary.
This is part of the code from the sketch builder menu example, edited to show where the extra code would go…
BLYNK_WRITE(V1) {
switch (param.asInt())
case 1: // Item 1
Serial.println("Item 1 selected");
// add the lines of code to blink the LED for a short duration here
break;
case 2: // Item 2
Serial.println("Item 2 selected");
// add the lines of code to blink the LED for a longer duration here
break;
Sorry for my poor response time.
I’ve followed your instructions, and built this sketch:
WidgetLCD lcd(V2);
BLYNK_WRITE(V1) {
case 1: // Item 1
Serial.println("Long Duration");
lcd.clear(); //Use it to clear the LCD Widget
lcd.print(0, 0, "Long Duration");
digitalWrite(LED_BUILTIN, LOW); // Turn the LED on (Note that LOW is the voltage level
// but actually the LED is on; this is because
// it is active low on the NODEMCU)
delay(200); // Wait for a second
digitalWrite(LED_BUILTIN, HIGH); // Turn the LED off by making the voltage HIGH
delay(300);
break;
case 2: // Item 2
Serial.println("Short Duration");
lcd.print(0, 0, "Short Duration");
delay(2000); // Wait for a second
delay(3000);
break;
default:
Serial.println("Unknown item selected");
After a successful upload, I selected one of the items and I’ve got nothing.
Any suggestions
No PinMode declaration and no use of the Ticker library (you can’t use delays like this with Blynk).
Pete
Thanks for the reminder.
GREAT!! my code works fine.
Thanks for the support.
I made the sketch again, and this is my code for who is intrested:
#include <Ticker.h>
char auth[] = "************";
char ssid[] = "SSID";
char pass[] = "Pass";
Ticker blinker;
void changeState()
digitalWrite(LED_BUILTIN, !(digitalRead(LED_BUILTIN))); //Invert Current State of LED
WidgetLCD lcd(V2);
BLYNK_WRITE(V1) {
case 1: // Item 1
blinker.attach(1, changeState); //time in seconds, for ms use attach_ms
break;
case 2: // Item 2
blinker.attach(.2, changeState); //Use attach_ms if you need time in ms
break;
default:
pinMode(LED_BUILTIN, OUTPUT);
