I have a raspi running Blynk-Library-Python to monitor my solar panels. I want to be able to write the solar wattage value to a ESP8266 that controls a device which I want to run only when the panels are generating above a certain level. I see many good examples for setting up the bridge code for Arduino, but none for python library. appreciate any help on proper syntax for python
import BlynkLib
import time
import smbus
import time
import struct
bus = smbus.SMBus(1)
address = 0x03
solar_data = [0.0,0.0,0.0,0.0]
BLYNK_AUTH = 'xxxxxxx'
# Initialize Blynk
# Register virtual pin handler
@blynk.VIRTUAL_READ(2)
def v2_read_handler():
global solar_data
valid = True
while valid:
try:
data = bus.read_i2c_block_data(address, 0);
valid = False
except:
print "Error getting data\n"
for i in range(0, 4):
bytes = data[4*i:4*i+4]
# Python 2 struct.unpack takes the data to be unpacked
# in string format, so the bytes need to be joined
solar_data[i] = struct.unpack('f', "".join(map(chr, bytes)))[0]
# This widget will show solar data..
blynk.virtual_write(2, solar_data[3])
# blynk.virtual_write(3, solar_data[0])
@blynk.VIRTUAL_READ(3)
def v3_read_handler():
global solar_data
# Start Blynk (this call should never return)
blynk.run()
