i want to set delays in the code. complete code have to be delay by a small time. but when i set delays it stops or i get unexpected output in timing. because i think when i set delay, wifi connection will lost and connecting wifi again??? so delay is too much
Use Blynk.timer timeout function. It’s like SimpleTimer and should work the same. Instructions on simpletimer use are on Arduino.cc
timer function works as timing from beginning nah?? i mean want to get the function exactly what delay does. i just wanted to delay everything for 5 seconds
Yes, that is possible with the timer. You can activate a function with a 5s delay, e.g. timer.setTimeout(5000, runThisFunctionAfterFiveSeconds);
