For my current project i have a prototype working for one room. Fully tested and everything works. Communication looks like this:
Thermostat (ESP) <—> Central (ESP) <—> Relay (ESP)
“<---->” are bridges between the 3 devices, ‘Central’ communicates with the Blynk app.
partial/relevant (removed a lot for readability) code here. Full code, if you’re interested, can be found here
So far so good. However now I need to add 6 more Thermostats (Rooms) and 3 more Relays (floor heating groups). So the obvious move is to shift everything (in the partial code) into a class and create one object per room.
however this makes me wonder, (start n00b mode:) when doing that, how can blynk.run() ‘access’ the blynk_xxx() functions of the objects? Or in other words, would that even work or better: HOW can I make that work? (end n00b mode).
well, the problem is that I don’t know how. A class is really simple you have e.g.
class whatever{ //declare class
public: //access specifier
int someInt;
int someFunction(){ someInt + 1};
whatever someObject; //create object from class:
someObject.someInt = 10; //use objects in code
cout << someObject.someFunction();
results in “11” on screen.
where this becomes useful is the fact that you can create limitless objects:
whatever anotherObject;
whatever andYetAnotherObject;
So basically if you have working code for one room which you wish to apply for lets say 7 rooms, you can cram the code for one room inside a class and declare 7 objects, each object representing one room. Clean and simple.
Where stuff goes hazy for me is this part: BLYNK_WRITE()
this function is created somewhere in the code by Blynk. And each loop blynk.run() will loop through and run ALL 128: BLYNK_WRITE(V0), BLYNK_WRITE(V1), BLYNK_WRITE(V2). The ones where you actually put code in e.g.
BLYNK_WRITE(V1){
int temperature = param.asInt();
will executed that internal code, the other BLYNK_WRITES() as they are empty won’t do anything.
Now if I move BLYNK_WRITE into a class structure, then its no longer exposed in the code and thus won’t get executed.
My question is: has anyone found a solution/trick/workaround for this?
@wolph42, Classes are great and are the “essence” of C++, I think… They are everywhere: in libraries, in more advanced projects… Unfortunately I know little about them, and currently only know how to share/access variables. Know nothing about functions. But IF YOU WILL handle that, please share!
P.S. All my "knowledge"in this aspect is no more than 2 weeks old, as I needed to adopt one of the common ESP firmwares to correctly support PMS sensor… That’s all…
…But perhaps sharing functions is not much different then variables?? For variables I’m using extern "C"
well that certainly makes me the senior expert then as my experience is exactly 2x as big
Its exactly one month ago when I started with this. This being EVERYTHING related to Arduino, including electronics, schemes, and coding in C++. Before that I wrote some visual basic scripts for excel and created some scripts for rptools’ maptool. Granted, I do have a Masters in Quantum Physics, but thats >15 years ago.
well, I was hoping I was, but I can’t find ANY inventor of ANY wheel ANYwhere. If you can point me to him/her or to the wheel that would be great!
@everyone: yes i will share if I get something OOP working with Blynk.
@vshymanskyy should you be checking this. I’ve created a class by I got stuck on constructing the widgetbridge objects. Below is part of the code which gives you the idea I went with. The error I got was:
no matching function for call to ‘WidgetBridge::WidgetBridge()’
Links to the full error message and code are below.
class Room {
private:
//initializer list of internal objects
WidgetBridge bridge_thermostat;
WidgetBridge bridge_relay;
public:
//Constructor of the class:
Room() : bridge_thermostat(V100), bridge_relay(V107){}
void initBridges(String authThermostat, String authRelay){
bridge_thermostat.setAuthToken(authThermostat);
bridge_relay.setAuthToken(authRelay);
void receiveCurrentT(float param){
currentT = param;
Blynk.virtualWrite(V10, currentT);
timer.restartTimer(thermostatTimer ); //reset isDead timer for thermostat
Blynk.setProperty(V17, "color", BLYNK_GREEN); //change LED color
Blynk.virtualWrite(V17, 200);
} livingRoom;
BLYNK_CONNECTED() {
Blynk.syncAll();
livingRoom.initBridges("xxx", "xxxx"); //auth of: thermostat, relay
BLYNK_WRITE(V10){ livingRoom.receiveCurrentT(param.asFloat()); } //receive currentT from thermostat
I have only the bareset understanding of ‘classes’ but after watching a video about how to make your own library (turns out you use classes ) in order to ‘clean up’ your code, I think I understand a bit better.
Issue I see though is that you are trying to take an existing library (Blynk) and shoehorn it into yet another form of class or library format… so, if even possible… to what benefit? aside from you own aesthetics of your code?
Well, @Gunner then remember yourself, that in similar manner works for example the DS1820 sensor library, which uses WIRE (if i recall) for it’s needs… And many, many more…
That is libraries working together, not conscripting one another into themselves or breaking themselves into seperate segments.
As I said, i have only a bare understanding… but taking Blynk functions that already work with the Blynk library and turning them into separate libraries/classes of their own doesn’t make sense. If it did, then I think a developer might have already chimed in… and still might?
not the answer you’re looking for, but for such cases when “classes” would be needed, i use arrays instead.
lets take your example, with the room, and say each room has the following members:
temperature actual
temperature target
heater relay gpio pin
i would create 3 arrays with the max number of the rooms (let’s say we have 10 rooms), with the needed types:
because all the arrays have the same length and indexing order, one can easily refer and write logic to any room any “member”, in all possible combinations:
#define HYST 1 // hysteresis
#define ROOMS 10
void checkRoomsTemp()
for (byte i = 0, i < ROOMS, i++) {
if (roomTemp[i] < roomTargetTemp[i]) digitalWrite(roomHeater[i], HIGH);
else if (roomTemp[i] > roomTargetTemp[i] + HYST) digitalWrite(roomHeater[i], LOW);
you can do the same for timers, timestamps, buttons, etc. for more complex projects you can even use multi dimensional arrays, like this:
int rooms[ROOMS][3];
rooms array has 3 registers, where:
[0] = actual temp
[1] = target temp
[2] = heater relay gpio pin
then, the above code example would look like this:
if (rooms[i][0] < rooms[i][1]) digitalWrite(rooms[i][2], HIGH);
else if (rooms[i][0] > rooms[i][1] + HYST) digitalWrite(rooms[i][2], LOW);
hope this makes sense… i used this strategy in several bigger projects and it worked great. if one designs the code carefully, it is very easy to scale the project:
for example, if you need to go from 10 room to 100, just replace the #define ROOMS 10 and ready to go. you do not have to change anything else in the code!
also, a bit different topic, but it is helpful for code organising and fragmenting, to use the tabs functionality in the arduino ide. i have wrote about this some time ago, here:
@Wanek: that’s really useful. I still want to check out the class method as its basically how c++ is intended, so IF you’re using c++ its a bit silly not to use its main strength.
On your method though: how do you pass on multidimensional arrays onto functions and return those? I’ve done some experimental coding to learn C and one of the things I tried was passing myVar[10][3] to a function and returning it with an operation, but that failed miserably. In the end I just made it global so I could continue.
to use the above method, the arrays must store persistent values, so you should either declare them static or global. from the memory footprint pov it doesn’t really matter actually, so i always declare them global.
i’m not sure what you ask here? afaik, c++ functions can’t return arrays…
