How to make vibration sensor sw420 trigger a relay.?and how to make phone call notification
How to make vibration sensor sw420 trigger relay?and how to make phone call notification
You’ll need a microcontroller to connect the sw420 and relay to, and that microcontroller will need to connect to the internet in some way. How you proceed will depend on the type of microcontroller and internet connection method you use.
Blynk can’t make phone calls as such. It can send notifications to a phone running the Blynk app, but that’s not a phone call.
*i found this code from Techiesms, i try the same code and compiled to tts go call esp32.,but the call didnt work
*the link of the project
Please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of the the code so that it displays correctly.
As this isn’t a Blynk related problem, I’d suggest that you’d probably be better raising it as an issue on the guy’s GitHub page and taking it from there.
Ok noted thank you sir.,i hope blynk will add phone call features in the future
