I’d put the capacitors as close as possible to the relay connectors, and make sure that they are X capacitors designed to be placed across line and neutral.
Little improvement has been done and further improvement to be done
http://twitter.com/blynk_app
This example runs directly on ESP8266 chip.
Please be sure to select the right ESP8266 module
in the Tools -> Board menu!
char auth[] = "1234555";
char ssid[] = "******";
char pass[] = "******";
#define speed_1_out D1 //Drive the relay one which is controlling the speed level one of the Fan
#define speed_2_out D2 //Drive the relay two which is controlling the speed level 2 of the Fan
#define speed_3_out D4 //Drive the relay three which is controlling the speed level 3 of the Fan
#define mainSwitch D3 //Drive the relay four which is turning of power to the fan
#define off_switch D5 //Read the momentary wsitch for off the fan
#define speed_1_switch D6 //Read the momentary wsitch for speed 1
#define speed_2_switch D7 //Read the momentary wsitch for speed 2
#define speed_3_switch D8 //Read the momentary wsitch for speed 3
unsigned char offSwitch = 0; //veriable to store status read from the " off_switch "
unsigned char speed_1_switch_read = 0; //veriable to store status read from the " speed_1_switch "
unsigned char speed_2_switch_read = 0; //veriable to store status read from the " speed_2_switch "
unsigned char speed_3_switch_read = 0; //veriable to store status read from the " speed_3_switch "
unsigned char speed_1_switch_detected = 0;
unsigned char speed_2_switch_detected = 0;
unsigned char speed_3_switch_detected = 0;
bool x = 1;
long offTime = 0;
int previous = LOW; // the previous reading from the input pin
long debounce = 200; // the debounce time, increase if the output flickers
long Time = 0; // the last time output pin was toggled//
long const OnOff_Duration = 5000;
long OnOff_Duration_offset = 0;
// Serial.begin(115200);
pinMode(speed_1_out , OUTPUT);
pinMode(speed_2_out , OUTPUT);
pinMode(speed_3_out , OUTPUT);
pinMode(mainSwitch , OUTPUT);
pinMode(off_switch , INPUT);
pinMode(speed_1_switch , INPUT);
pinMode(speed_2_switch , INPUT);
pinMode(speed_3_switch , INPUT);
digitalWrite(speed_1_switch, HIGH);
digitalWrite(speed_2_switch, HIGH);
digitalWrite(speed_3_switch, HIGH);
digitalWrite(speed_1_out, HIGH);
digitalWrite(speed_2_out , HIGH);
digitalWrite(speed_3_out, HIGH);
digitalWrite(mainSwitch, HIGH);
OnOff_Duration_offset = OnOff_Duration;
main_Switch();
void main_Switch() {
if ((millis() - offTime) > OnOff_Duration_offset)//150000
offTime = millis();
digitalWrite(mainSwitch, x = !x);
if (digitalRead(speed_1_out) == HIGH && digitalRead(speed_2_out) == HIGH && digitalRead(speed_3_out) == HIGH ) {
read_switch(); //read status of speed selector switch
void read_switch() {
speed_1_switch_read = digitalRead(speed_1_switch);
if (speed_1_switch_read == HIGH && previous == LOW && millis() - Time > debounce) {
speed_1_switch_detected = 1;
speedSwitch('L');
speed_2_switch_read = digitalRead(speed_2_switch);
if (speed_2_switch_read == HIGH && previous == LOW && millis() - Time > debounce) {
speed_2_switch_detected = 1;
speedSwitch('M');
speed_3_switch_read = digitalRead(speed_3_switch);
if (speed_3_switch_read == HIGH && previous == LOW && millis() - Time > debounce) {
speed_3_switch_detected = 1;
speedSwitch('N');
offSwitch = digitalRead(off_switch);
if (offSwitch == HIGH && previous == LOW && millis() - Time > debounce) {
speedSwitch('O');
} // End of readSwitch2 function
BLYNK_WRITE(V1) { // Widget for interval timing
switch (param.asInt())//param.asInt()
case 1: { // off
speedSwitch('O');
break;
case 2: { // speed 1
speedSwitch('L');
break;
case 3: { // speed2
speedSwitch('M');
break;
case 4: { // speed 3
speedSwitch('N');
break;
BLYNK_WRITE(V4) {
int value = param.asInt(); // This gets the 'value' of the Widget as an integer
OnOff_Duration_offset = OnOff_Duration * value;
void speedSwitch(unsigned char Speed) {
switch (Speed) {
case 'L': { // speed1
digitalWrite(speed_1_out, LOW);
digitalWrite(speed_2_out, HIGH);
digitalWrite(mainSwitch, LOW);
offTime = millis();
Time = millis();
x = 1;
break;
case 'M': { // speed 2
digitalWrite(speed_2_out, LOW);
offTime = millis();
Time = millis();
x = 1;
break;
case 'N': { // speed 3
digitalWrite(speed_3_out, LOW);
offTime = millis();
Time = millis();
x = 1;
break;
case 'O': { // off
Time = millis();
break;
Doesn’t look like it will work to me.
What do you think about RC Snubber cct to reduce EMF
A capacitor worked perfectly for me when I had a similar problem.
I replaced the 4 capacitors across the AC line . Now everything is working perfectly. Thanks for your grate support
Now I have to improve the code and change to the ESP32
Thanks one again
My Fan is still working no error
Hoped you are doing well
Suddenly my system stop . Can not understand the reason
I believe that Auth Token has been changed some how .
Your serial monitor will give an “Invalid Auth Token” message if that is the case.
Was this project a success? If so, can you put the circuit diagram and code?
Yes it is working successfully
Please follow the thread it has everything,
If you need any additional info please post here
Sorry for late reply
Yes This is good for celling fan
Why not for pedestal fan instead of relay ? ![]()
The pedestal fan what I am using comes with three winding for speed control but Celling fan just two wire . What do you think
I think you have to push the fast speed button level 3 and use the module as a AC dimmer at the input AC
Yes ,… That is good idea but I don’t have experience working with that way
Does it working
In this case we have to remove the latching selector switches which originally comes with right ?
How do we manage manual control and app slider control
