hey guys, i tried saving the java command into a batch file and making that start, but because the CMD window it starts doesn’t have admin permissions, things don’t work as they should. how do i do this? the most elegant way i can think of is using NSSM to make blynk a service, but not sure how since its not a executable. anyone with any solution no matter how convulated will be much appreciated.
anyone cracked this ^ ?
I don’t understand why win requires you to be an admin, but if so you can run bat file as Administrator. Did you try that?
the problem is making run at startup as administrator
this was helpful, thank you. i cant imagine how i missed it in my own searches.
