if my ESP8266 is power loss or hotspot loss…setting turn ON timer is reseting then relay OFF. how to solve this problem…? thank you
* timeinput.ino Demonstrate interaction of Time library with
* Blynk's TimeInput widget.
* App project setup:
* RTC widget (no pin required!!!)
* V1 : Manual/Auto button
* V2: On-off button
* Time Input widget on V8 (All days)
* Button selection for Time Input (All days) on V9
* Time Input widget on V10 (Up to you)
* Button selection for Time Input (Up to you) on V11
#define BLYNK_DEBUG // Optional, this enables lots of prints
#include <ESP8266_Lib.h>
#include <TimeLib.h>
#include <WidgetRTC.h>
#include <DHT.h>
#include <LiquidCrystal.h>
#define DHTPIN 3 // What digital pin we're connected to
LiquidCrystal lcd(13, 8, 7, 6, 5, 4);
const int relay1 = A0;
const int relay2 = A1;
const int relay3 = A5;
int humLowTrigger;
int tempHighTrigger;
char auth[] = "c2d143sssa2f9e";
char ssid[] = "kxxxxadi";
char pass[] = "polytron";
#include <WidgetLED.h>
#define TestLED 9 // on board LED pin assignment
char Date[16];
char Time[16];
long startsecondswd; // weekday start time in seconds
long stopsecondswd; // weekday stop time in seconds
long nowseconds; // time now in seconds
bool isFirstConnect = true;
int manual=0;
int oldstatus;
int alldays;
//int uptoyou;
SoftwareSerial EspSerial(10, 11); // RX, TX
#include <TimerOne.h> // Avaiable from http://www.arduino.cc/playground/Code/Timer1
volatile int i=0; // Variable to use as a counter volatile as it is in an interrupt
volatile boolean zero_cross=0; // Boolean to store a "switch" to tell us if we have crossed zero
int AC_pin = 12; // Output to Opto Triac
int brightness = 128; // Dimming level (0-128) 0 = on, 128 = 0ff
int freqStep = 75; // This is the delay-per-brightness step in microseconds.
int val = 0;
const byte degreeSymbol = B11011111; //Simbol Degree
int autodimmer;
#define ESP8266_BAUD 9600
//#define ESP8266_BAUD 115200
WidgetRTC rtc;
ESP8266 wifi(&EspSerial);
DHT dht(DHTPIN, DHTTYPE);
void updateHum(int param);
void updateTemp(int param);
//BlynkTimer timer;
BLYNK_WRITE(V5) {
updateHum(param.asInt());
BLYNK_WRITE(V6) {
updateTemp(param.asInt());
void Readdata()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
lcd.print("ERROR");
return;
lcd.setCursor(0, 0); //
lcd.print("TMP:");
lcd.print((int)t);
lcd.write(degreeSymbol); // Tulis simbol derajat
lcd.print("C");
//menampilkan nilai suhu pada LCD
lcd.setCursor(9, 0);
lcd.print("HUM:");
lcd.print((int)h);
lcd.println("%");
lcd.setCursor(0, 1);
lcd.print("JAM:");
if(hour() < 10)
lcd.print("0");
lcd.print(hour(), DEC); //Print hour
lcd.print(':');
if(minute() < 10)
lcd.print("0");
lcd.print(minute(), DEC); //Print min
Blynk.virtualWrite(V15, h);
Blynk.virtualWrite(V16, t);
Blynk.virtualWrite(V25, humLowTrigger);
Blynk.virtualWrite(V24, tempHighTrigger);
if(h < humLowTrigger) {
digitalWrite(relay1, LOW);
Blynk.virtualWrite(V26, 255);
digitalWrite(relay1, HIGH);
Blynk.virtualWrite(V26, 0);
if(t < tempHighTrigger) {
digitalWrite(relay2, HIGH);
Blynk.virtualWrite(V27, 0);
digitalWrite(relay2, LOW);
Blynk.virtualWrite(V27, 255);
void updateHum(int param) {
humLowTrigger = param;
void updateTemp(int param){
tempHighTrigger = param;
void zero_cross_detect() {
zero_cross = true;
i=0;
digitalWrite(AC_pin, LOW); // turn off TRIAC (and AC)
// Turn on the TRIAC at the appropriate time
void dim_check() {
if(zero_cross == true) {
if(i>=brightness) {
digitalWrite(AC_pin, HIGH); // turn on light
i=0; // reset time step counter
zero_cross = false; //reset zero cross detection
else {
i++; // increment time step counter
lcd.begin(16, 2);
dht.begin();
pinMode(AC_pin, OUTPUT); // Set the Triac pin as output
attachInterrupt(0, zero_cross_detect, RISING); // Attach an Interupt to Pin 2 (interupt 0)
Timer1.initialize(freqStep); // Initialize TimerOne library
Timer1.attachInterrupt(dim_check, freqStep);
delay(10); // stabil
Blynk.syncAll();
timer.setInterval(10000, Readdata); // stabil
pinMode(relay1, OUTPUT);
pinMode(relay2, OUTPUT);
pinMode(relay3, OUTPUT);
digitalWrite(relay3, HIGH);
int humLowTrigger = 65;
int TempHighTrigger = 20;
pinMode(TestLED, OUTPUT);
digitalWrite(TestLED, HIGH); // set LED OFF
int mytimeout = millis() / 1000;
while (Blynk.connect() == false) { // try to connect to server for 10 seconds
if((millis() / 1000) > mytimeout + 8){ // try local server if not connected within 9 seconds
break;
rtc.begin();
timer.setInterval(30000L, activetoday); // check every 10 SECONDS if schedule should run today
timer.setInterval(20000L, reconnectBlynk); // check every 30s if still connected to server
BLYNK_CONNECTED() {
Blynk.syncAll();
if (isFirstConnect) {
// Blynk.syncVirtual(V8); // sync timeinput widget
//Blynk.syncVirtual(V9); // sync timeinput widget
Blynk.notify("TIMER STARTING!!!!");
rtc.begin();
isFirstConnect = false;
void activetoday(){ // check if schedule should run today
if(year() != 1970){
if (alldays==1) {
// Blynk.syncVirtual(V9); // sync timeinput widget
void checklastbuttonpressed (){
if(alldays==1)
{ oldstatus=1; }
if(alldays==0)
{ oldstatus=0; }
void restorelastbuttonpressed (){
if(oldstatus==1){
alldays=1;
Blynk.virtualWrite(V9, 1);}
if(oldstatus==0){
alldays=0;
Blynk.virtualWrite(V9, 0);
BLYNK_WRITE(V3)// slider brillo
int brillo = param.asInt();
if (autodimmer == 0) // If auto dimmer is OFF then set the dimmer according slider value
brightness=brillo;
BLYNK_WRITE(V1) // Manual/Auto selection
if (param.asInt()==1) {
manual=1;
checklastbuttonpressed ();
alldays=0;
//uptoyou=0;
restorelastbuttonpressed ();
manual=0;
BLYNK_WRITE(V7) // Manual/Auto selection
digitalWrite(relay3, LOW);
void resetManual()
Blynk.virtualWrite(V1, 0); //Turn OFF Manual Mode Widget
Blynk.virtualWrite(V2, 0); //Turn OFF Button Widget Device
lcd.setCursor(10, 1);
lcd.print("L-OFF");
BLYNK_WRITE(V2) // ON-OFF Manual
if (param.asInt()==1) { // boton encendido
if (manual==0){ //está en modo automático
manual=1;
alldays=0;
Blynk.virtualWrite(V1, 1);
digitalWrite(TestLED, LOW); // set LED ON
Blynk.virtualWrite(V2, 1); //Turn ON Button Widget
lcd.print("L--ON");
} else { //está en modo manual
alldays=0;
lcd.print("L--ON");
}else {
if (manual==0){ //modo automático
manual=1;
alldays=0;
lcd.print("L-OFF");
alldays=0;
lcd.print("L-OFF");
BLYNK_WRITE(V9) // All days selected
timer.setTimeout(50, resetManual);
timer.setTimeout(50, checklastbuttonpressed);
alldays=1;
// Blynk.virtualWrite(V11, 0);
alldays=0;
BLYNK_WRITE(V8)//All days
if (alldays==1) {
TimeInputParam t(param);
int dayadjustment = -1;
if(weekday() == 1){
dayadjustment = 6; // needed for Sunday, Time library is day 1 and Blynk is day 7
if(t.isWeekdaySelected(weekday() + dayadjustment)){ //Time library starts week on Sunday, Blynk on Monday
for (int i = 1; i <= 7; i++) { // Process weekdays (1. Mon, 2. Tue, 3. Wed, ...)
if (t.isWeekdaySelected(i)) {
// nowseconds = ((hour() * 3600) + (minute() * 60) + second());
nowseconds = long(hour() * 3600L) + long(minute() * 60L) + long (second());
startsecondswd = (t.getStartHour() * 3600) + (t.getStartMinute() * 60);
stopsecondswd = (t.getStopHour() * 3600) + (t.getStopMinute() * 60);
//Serial.println(startsecondswd); // used for debugging
if(startsecondswd == stopsecondswd) {
lcd.print("L-OFF");
if(startsecondswd < stopsecondswd){ // 90s on 60s timer ensures 1 trigger command is sent
if ((nowseconds >= startsecondswd) && (nowseconds < stopsecondswd) ){
digitalWrite(TestLED, LOW); // set LED On
lcd.print("L--ON");
else if (nowseconds >= stopsecondswd){
digitalWrite(TestLED, HIGH); // set LED On
lcd.print("L-OFF");
else {
lcd.print("L-OFF");
if(startsecondswd > stopsecondswd){ // 90s on 60s timer ensures 1 trigger command is sent
if ((nowseconds >= startsecondswd) && (nowseconds <= 82800)){
lcd.print("L--ON");
else if (nowseconds < stopsecondswd){
lcd.print("L--ON");
else if (nowseconds >= stopsecondswd && nowseconds < startsecondswd ){
lcd.print("L-OFF");
else{
// nothing to do today, check again in 30 SECONDS time
//terminal.println();
void reconnectBlynk() {
if (!Blynk.connected()) {
if(Blynk.connect()) {
BLYNK_LOG("Reconnected");
BLYNK_LOG("Not reconnected");
if (Blynk.connected()) {
// yield();
