How to let device working without WIFI connection?
I have the sketch its work fine now, and I try to combine it with Blynk and it also work fine now while WIFI connected.
but I need to let its continue work even my WIFI router is down.
I’v try to search and try to
     if((millis() / 1000) > mytimeout + 8){  // try for less than 9 seconds
       break;
still not work.
 #include <ESP8266_Lib.h>
 char auth[] = "xxxx";
 char ssid[] = "xxxx";
 char pass[] = "xxxx";
 #define EspSerial Serial
 //#include <SoftwareSerial.h>
 // Your ESP8266 baud rate:
 #define ESP8266_BAUD 115200
 ESP8266 wifi(&EspSerial);
   long previousMillis = 0;
   long rept=36000;
   long interval=9000;
 pinMode(2, OUTPUT);
 pinMode(3, OUTPUT);
 pinMode(4, OUTPUT);
 pinMode(5, OUTPUT);
   //int Le1 =12;
   // Set ESP8266 baud rate
   //Blynk.begin(auth, wifi, ssid, pass, "blynk-cloud.com", 8442);
   //Blynk.begin(auth, wifi, ssid, pass, IPAddress(192,168,1,100), 8442);
 unsigned long currentMillis = millis();
   if(currentMillis - previousMillis > rept)
     digitalWrite(2, HIGH);
     if(currentMillis - previousMillis > rept+interval)
       digitalWrite(2, LOW);
       digitalWrite(3, HIGH);
       if(currentMillis - previousMillis > rept+interval+interval)
         digitalWrite(3, LOW);
         digitalWrite(4, HIGH);
           if(currentMillis - previousMillis > rept+interval+interval+interval)
             digitalWrite(4, LOW);
             digitalWrite(5, HIGH);
              if(currentMillis - previousMillis > rept+interval+interval+interval+interval)
               digitalWrite(5, LOW);
Thanks in advance
You need to integrate BlynkTimer, move much of your running code into a timed loop instead of in the void loop() and then add in the connection management commands… search this forum for keywords like connection management for more examples.
http://docs.blynk.cc/#blynk-firmware-blynktimer
http://help.blynk.cc/
@Gunner did I see a library hack on the forum recently for connection management of ESP shield’s?
Yes… I finally found it :slight_smile: However it was more a “reset if not connected”, then a “keep running code when not connected” thing.
I have tried to search connection management
   long rept=36000;
   long interval=9000;
 pinMode(2, OUTPUT);
 pinMode(3, OUTPUT);
 pinMode(4, OUTPUT);
 pinMode(5, OUTPUT);
 pinMode(6, OUTPUT);
 if (Blynk.connected()==false)
 char auth[] = "xxxxxx";
   char ssid[] = "xxxxxx";
     int mytimeout = millis() / 1000;
       break;
look like,
Its need a first time to connected WIFI for make my program succeed.
If no first time WIFI connected its do nothing.
I think
struck in loop Blynk.begin(auth, wifi, ssid, pass); of #include <BlynkSimpleShieldEsp8266.h>
How to seperrate this function of BlynkSimpleShieldEsp8266.h Library to
  1. wifi connecting and 2.blynk connecting
limited connecting time of Blynk.begin
sorry for my bad English
Then you missed the part about using Blynk.config() instead of Blynk.begin()
http://docs.blynk.cc/#blynk-firmware-connection-management
Opps… just noticed (again) that you seem to be using Arduino with ESP as a shield…
OK, many of the connection management methods don’t work properly with the shield library. Probably because they require to be running ON an ESP… but when used as a shield, the ESP is just a separate Serial to WiFi adapter and all code runs ON the Arduino.
Hello Blynkers,. I’m a beginer and I have the project and I’m using Ethernet shield and Arduíno Mega, I did the routine If (Blynk.connected()){Blynk.run} and the reconnection routine too, and now, when dont have internet the code with physical buttons Works well, but, Just we had a fisrt internet connection,… When I energized arduíno without internet the code dosent Works .
How Can I solve this problem?
Can you clarify exactly what this statement means please?
It would also be useful if you posted your code, correctly formatted with triple backticks at the beginning and end.
