Hello, I am making the transmission of ECG data with Arduino and GSM (SIM900) over Blynk, and that data should be loaded into Python and analyzed in real time. Is that possible with Blynk? I tried some simple code in Python, but nothing happened when running. I am still not that familiar with Python and possibly didn’t put something important which whould solve the thing.
The other thing I tried is to use webhook and send the data to Thingspeak which I eventually succeeded, but the data Thingspeak is displaying is incorrect! I used DHT11 sensor for the trial since I am still waiting to get that ECG.
Does anyone have an idea how to solve any of those two issues? My Arduino and Python codes are below.
Arduino code:
#include "DHT.h"
// Select your modem:
//#define TINY_GSM_MODEM_SIM800
#define TINY_GSM_MODEM_SIM900
//#define TINY_GSM_MODEM_M590
//#define TINY_GSM_MODEM_A6
//#define TINY_GSM_MODEM_A7
//#define TINY_GSM_MODEM_BG96
//#define TINY_GSM_MODEM_XBEE
// Default heartbeat interval for GSM is 60
// If you want override this value, uncomment and set this option:
//#define BLYNK_HEARTBEAT 30
#define BLYNK_TIMEOUT_MS 15000UL
#define DHTPIN 2
#define DHTTYPE DHT11
// Initialize DHT sensor for normal 16mhz Arduino
DHT dht(DHTPIN, DHTTYPE);
// Create global varibales to store temperature and humidity
float t; // temperature in celcius
float f; // temperature in fahrenheit
float h; // humidity
#include <TinyGsmClient.h>
#include <BlynkSimpleSIM800.h>
char auth[] = "auth";
char thingspeak = "thingspeak_write_api";
// Your GPRS credentials
// Leave empty, if missing user or pass
char apn[] = "apn";
char user[] = "usr";
char pass[] = "pass";
// Hardware Serial on Mega, Leonardo, Micro
//#define SerialAT Serial1
// or Software Serial on Uno, Nano
//#include <SoftwareSerial.h>
//SoftwareSerial SerialAT(2, 3); // RX, TX
SoftwareSerial SerialAT(7,8);
TinyGsm modem(SerialAT);
timer.setInterval(17000L, SendtoThingspeak);
pinMode(8, OUTPUT);
digitalWrite(8, HIGH);
digitalWrite(8, LOW);
dht.begin();
// Set GSM module baud rate
SerialAT.begin(9600);
delay(3000);
modem.restart();
// Unlock your SIM card with a PIN
//modem.simUnlock("1234");
t=readTemp();
h=readHum();
Serial.print(t);
Serial.println(" *C");
Serial.print(h);
Serial.println(" %");
Blynk.virtualWrite(V1, t);
delay(5000);
Blynk.virtualWrite(V2, h);
delay(5000);
float readTemp() {
// Read temperature as Celsius
t = dht.readTemperature();
//Read humidity
h = dht.readHumidity();
// Compute temperature values in Celcius
t = dht.computeHeatIndex(t,h,false);
// Check if any reads failed and exit early (to try again).
if (isnan(t)) {
Serial.println("Failed to read temp from DHT sensor!");
return 1;
return t;
float readHum() {
//Read humidity
if (isnan(h)) {
Serial.println("Failed to read hum from DHT sensor!");
return 1;
return h;
void SendtoThingspeak()
String t = String(dht.readTemperature());
Blynk.virtualWrite(V0, t);
Python code:
# -*- coding: utf-8 -*-
Created on Sat Aug 10 23:45:00 2019
@author: Milos
import blynklib
import random
BLYNK_AUTH = '2Wl_LQwI1W_-6RTpecDeK9OPZ0WrMTAT'
# initialize blynk
blynk = blynklib.Blynk(BLYNK_AUTH)
READ_PRINT_MSG = "[READ_VIRTUAL_PIN_EVENT] Pin: V{1}"
# register handler for virtual pin V11 reading
@blynk.handle_event('read V1')
def read_virtual_pin_handler(pin):
print(READ_PRINT_MSG.format(pin))
a=blynk.virtual_read(pin, random.randint(0, 255))
while True:
blynk.run()
print(a)
# infinite loop that waits for event
#while True:
# blynk.run()
