Hello everyone,
I am working on Home automation project.
I need to get Physical state of AC loads such as fans,bulbs etc.
I need both switching manually (from buttons)and from microcontroller.(Nodemcu with relay).
With Physical state indication using LED Widget.
My question is
How to get physical state(ON/OFF)??
Does it required rectifier circuit to convert AC to DC to get physical state of AC load to microcontroller??
Or any other Device is available ??
I had uploaded this code.my code is ready.
Please read topic carefully.
I need physical state AC Devices(such as T.V,Fan which runs on alternating current.)
I need two switching one from microcontroller &from buttons.
You can just use a normal relay and a two way switching to do the same thing in the video. But if you want to show the physical state in the app you are going to need a sensor to check that (voltage regulator, step-down transformer, current sensor, etc).
This way you use the Blynk App to control the Relay and can also use the physical button. With a sensor close to your load you can see if it’s On/Off. The only problem is that depending on the position of your physical button the relay will have to stay activated to keep the load off, consuming some power.
