What are you seeing in your terminal monitor ? (copy and paste the results, and use triple backticks again).
Does your device show as being online in the app?
There is nothing showing in the terminal monitor and moreover my device is not being showing online. I select NodeMCU and connection type is WIFI from app.
Set the baud rate in the serial monitor(115200). And reset the module (make sure you have connected the module to the pc and select the correct com port). It should throw some info in the serial monitor saying the module is connected to the wifi router you have specified in the code.
I already set baud rate in the serial monitor (115200) and also select the correct com port and after upload the code, i checked the serial monitor which is connected to com port 5 but didn’t appeared any kind of word like --“connected to the wifi router”. Is there any kind of trouble shooting option for proper solution??
What does appear in your serial monitor when you press the reset button on the NodeMCU?
If nothing appears at all then you’re doing something wrong.
If something appears then post it here.
This project was to create an atmosphere, when smart devices will near to this ESP8266, it will display the connected devices IP address and MAC address through Serial monitor which i have already shown on the upper comments. Now i just want to use blynk app to display the connected devices on terminal of blynk instead of arduino builtin serial monitor. That’s it.
So you’re wanting multiple ‘smart devices’ to connect to your ESP8266 and for that ESP8266 to report their IP address via Blynk. Is that correct?
If that’s not what you’re trying to achieve then PLEASE explain in much more detail, as it’s impossible to help at the moment with the information you’ve provided.
I don’t believe that it’s possible for an ESP8266 to have multiple smart devices connected to it, and for it to effectively act as a router for these devices.
The sensible solution would be for these smart devices to connect directly to Blynk.
But, you’re not sharing enough information for people to fully understand d what it is that you’re trying to achieve, and why you’re trying to achieve it.
