I need help with trying to find a command line so I can use the Port from the Raspberry Pi Breadboard. I am using Virtual Pins, so I don’t know if I am supposed to use analogRead() or Am I supposed to use a different code. Also, will I need an ADC Chip for this?
Flex sensor is an analog device
//Constants:
const int flexPin = A0; //pin A0 to read analog input
//Variables:
int value; //save analog value
void setup(){
void loop(){
value = analogRead(flexPin); //Read and save analog value
Serial.println(value); //Print value
The Raspberry Pi has all digital ports, does this mean I need an ADC (Analog to Digital Converter) chip? Also, How would I plug the Flex Sensor in and find the right port for it? Thank you so much for your help.
OMG ! no good to hear that !
there is a tutorial here :
Not a Blynk Related topic. Please use Google and/or Raspberry Pi Forum first to figure out RPi hardware issues like Analog sensors.
