How to emlinate D3 and D4 pin be HIGH after re-connect the WiFi or power on NodeMCU 1.0 (ESP8266)?
Hi Everyone,
My project working on a 24V signal alarm system using NodeMCU and Blynk.
When a 24V signal is ON, it will be converted into 3.3V and input to one pin onboard.
When the pin sense it becomes HIGH, a bit value will be sent,
(e.g. D0 pin sent bit(0), D1 pin sent bit(1), D2 pin sent bit(2)…till D10)
otherwise, ZERO will be sent.
(i.e. the program would like to know the hardware status on the board, NOT the widget status)
The program will scan the pin status for every 15 seconds, and the status and the real time will be written into V1 pin, so that I can view V1 value on HTTP API.
However, by the characteristic of D3 / D4 pin on NodeMCU, it is always HIGH when the board is reset, even I defined those are INPUT pin.
For example, if Now D0, D1, D2 are HIGH, the status now should be 000 0000 0111,
but if the board is disconnected from the WiFi or power, after re-connected the board,
the status will be 000 0001 1111.(in real condition, D3 and D4 do not have any 24V signal come in)
I need to reset the D3 D4 pin by clicking the responding button widgets on BLYNK app once, then the problem will be solved, but I dont want to do this by manually, even I try to use digitalWrite(D3, LOW) in setup(), it can’t work. Any one could help me on this?
Below are my codes
//#define BLYNK_MAX_SENDBYTES 128
#include <WiFiUdp.h>
#include <NTPClient.h>
char auth[] = "xxx";
char ssid[] = "xxx";
char pass[] = "xxx";
const String SiteNo = "YYY";
String formattedDate;
WiFiUDP ntpUDP;
NTPClient timeClient(ntpUDP);
volatile word bFlag; //Status of whole system
volatile word bFlag0; //Status of air blower 1
volatile word bFlag1; //Status of air blower 2
volatile word bFlag2; //Status of air blower 3
volatile word bFlag3; //Status of air blower 4
volatile word bFlag4; //Status of air blower 5
volatile word bFlag5; //Status of air blower 6
volatile word bFlag6; //Status of air blower 7
volatile word bFlag7; //Status of air blower 8
volatile word bFlag8; //Status of air blower 9
volatile word bFlag9; //Status of air blower 10
volatile word bFlag10; //Status of air blower 11
int powerpin = 16;
int eqHigh = 5;
int eqLow = 4;
int mbrHigh = 0;
int mbrLow = 2;
int b1pin = 14;
int b2pin = 12;
int p1pin = 13;
int p2pin = 15;
int p3pin = 3;
int p4pin = 1;
BlynkTimer timer1;
  Blynk.notify(String(SiteNo) + " online");
  pinMode(powerpin, INPUT); //Initial is 0V
  pinMode(eqHigh, INPUT); //Initial is 0V
  pinMode(eqLow, INPUT); //Initial is 0V
  pinMode(mbrHigh, INPUT); //Initial is 0V
  pinMode(mbrLow, INPUT); //Initial is 0V
  pinMode(b1pin, INPUT); //Initial is 0V
  pinMode(b2pin, INPUT); //Initial is 0V
  pinMode(p1pin, INPUT); //Initial is 0V
  pinMode(p2pin, INPUT); //Initial is 0V
  pinMode(p3pin, INPUT); //Initial is 0V
  pinMode(p4pin, INPUT); //Initial is 0V
  digitalWrite(mbrHigh, LOW);
  digitalWrite(mbrLow, LOW);
  timer.setInterval(30000L, system_status);
  timer1.setInterval(15000L, signal_read);
  timeClient.begin();
  timeClient.setTimeOffset(28800);
void signal_read()
  int PowerFault = digitalRead(powerpin); //Power Supply
  if (PowerFault == HIGH) //if this pin is 3.3V
    bFlag0 = bit(0); //this byte changes to 000 0000 0001
   else if
    (PowerFault == LOW)
    bFlag0 = 0x00; //if this pin is 0v, changes to 0000 0000
  int EQTankH = digitalRead(eqHigh); //Eq tank high level
  if (EQTankH == HIGH) //if this pin is 3.3V
    bFlag1 = bit(1); //this byte changes to 000 0000 0010
   else if
    (EQTankH == LOW)
    bFlag1 = 0x00; //if this pin is 0v, changes to 0000 0000
  int EQTankL = digitalRead(eqLow); //Eq tank low level
  if (EQTankL == HIGH) //if this pin is 3.3V
    bFlag2 = bit(2); //this byte changes to 000 0000 0100
   else if
    (EQTankL == LOW)
    bFlag2 = 0x00; //if this pin is 0v, changes to 0000 0000
  int MBRTankH = digitalRead(mbrHigh); //mbr high level
  if (MBRTankH == HIGH) //if this pin is 3.3V
    bFlag3 = bit(3); //this byte changes to 000 0000 1000
   else if
    (MBRTankH == LOW)
    bFlag3 = 0x00; //if this pin is 0v, changes to 0000 0000
  int MBRTankL = digitalRead(mbrLow); //mbr low level
  if (MBRTankL == HIGH) //if this pin is 3.3V
    bFlag4 = bit(4); //this byte changes to 000 0001 0000
   else if
    (MBRTankL == LOW)
    bFlag4 = 0x00; //if this pin is 0v, changes to 0000 0000
  int B1Fault = digitalRead(b1pin); //Air Blower No.1 fault
  if (B1Fault == HIGH) //if this pin is 3.3V
    bFlag5 = bit(5); //this byte changes to 000 0010 0000
   else if
    (B1Fault == LOW)
    bFlag5 = 0x00; //if this pin is 0v, changes to 0000 0000
  int B2Fault = digitalRead(b2pin); //Air Blower No.2 fault
  if (B2Fault == HIGH) //if this pin is 3.3V
    bFlag6 = bit(6); //this byte changes to 000 0100 0000
   else if
   (B2Fault == LOW)
    bFlag6 = 0x00; //if this pin is 0v, changes to 0000 0000
  int P1Fault = digitalRead(p1pin); //P1 pump fault
  if (P1Fault == HIGH) //if this pin is 3.3V
    bFlag7 = bit(7); //this byte changes to 000 1000 0000
   else if
   (P1Fault == LOW)
    bFlag7 = 0x00; //if this pin is 0v, changes to 0000 0000
  int P2Fault = digitalRead(p2pin); //P2 pump fault
  if (P2Fault == HIGH) //if this pin is 3.3V
    bFlag8 = bit(8); //this byte changes to 001 0000 0000
  else if
   (P2Fault == LOW)
    bFlag8 = 0x00; //if this pin is 0v, changes to 0000 0000
  int P3Fault = digitalRead(p3pin); //P3 pump fault
  if (P3Fault == HIGH) //if this pin is 3.3V
    bFlag9 = bit(9); //this byte changes to 010 0000 0000
   else if
   (P3Fault == LOW)
    bFlag9 = 0x00; //if this pin is 0v, changes to 0000 0000
  int P4Fault = digitalRead(p4pin); //P4 pump fault
  if (P4Fault == HIGH) //if this pin is 3.3V
    bFlag10 = bit(10); //this byte changes to 100 0000 0000
   else if
   (P4Fault == LOW)
    bFlag10 = 0x00; //if this pin is 0v, changes to 0000 0000
void system_status()
  bFlag = bFlag0 |= bFlag1 |= bFlag2 |= bFlag3 |= bFlag4 |= bFlag5 |= bFlag6 |= bFlag7 |= bFlag8 |= bFlag9 |= bFlag10;
    timeClient.update();
   formattedDate = timeClient.getFormattedDate();
  String message = String(bFlag, BIN) + " " + String(formattedDate);
   Blynk.virtualWrite(V1, String(message));
   Blynk.notify(String(SiteNo) + " "+ String(message));
  timer1.run();
Have you tried doing what you’ve done for these two pins:
with your GPIO3 and GPIO4 (p3pin and eqLow) pins?
BTW, It’s very easy to get confused when working with NodeMCU boards as the “D” pin numbering printed on the boards bears no resemblance to the GPIO pin numbering used in the Blynk app. I had to re-read your explanation of the issue several times to work-out that your D pin references were in fact GPIO numbers. As you can see, I prefer to refer to GPIO when I’m referring to digital pin numbering, and D numbers when talking about whats printed on the board
You have misunderstand.
My question focuses on D3 and D4 pins,
which means GPIO 0 and GPIO 2 , according to the NodeMCU mapping,
which means mbrHigh and mbrLow.
Yes, mixing D and GPIO numbers lead me to think you were talking about Blynk app D pin references, not NodeMCU pin labeling!
Maybe the outputs from your alarm panel are floating slightly when inactive, which may need a pull-down resistor? A check with a meter should tell you whether this is a problem.
Having a Blynk widget button attached to a Digital (GPIO) pin can cause issues with that pin being pulled low. It’s better to attach the Blynk widget to a virtual pin and have a corresponding BLYNK_WRITE(Vpin) statement that does a digitalWrite to the required NodeMCU pin.
From what you’ve said, the Blynk button is only needed to overcome this issue in the first place, but maybe something you’ve done since has solved the original problem and removing the Blynk connection to that digital pin may actually solve the problem?
