I have a project with four tabs in the Tab Widget, each tab displays the same range of data from separate areas of my house. Each tab has nine widgets and multiple data sources. I want to create a new tab with the same layout, same widgets for a new area in the house.
Is there a way to duplicate a tab (all layout, customisations, pin assignments etc), add all these settings to the new tab, then I’ll just change the associated device as required?
That is true… most settings are retained, you just need to reset the vpin and then drag the cloned widget to the new tab and reposition it. Minor improvement over starting from scratch, but still not without picky efforts when dealing with a full screen of widgets.
But, apparently if you hover the “to be copied” widget over the duplication icon (as I inadvertently did while trying to screenshot it), it will keep automatically making new copies (not a bad feature now that I know about it)
