@L4GSpike I had a look at the BlynkSimpleShieldEsp8266.h library and it seems that the IP address should be obtainable.
I then had a look at the sketch builder examples and realised that WiFi object is referenced as ‘wifi’ (all lower case, like this:
ESP8266 wifi(&EspSerial);
So, for the first time ever, I dug-out an Arduino Mega and an ESP-01 module and had a play around
It turns-out that you can call wifi.getLocalIP()
, but the problem is that it returns both the IP and Mac address, plus some unwanted characters that come from the AT command structure. The format looks like this:
+CIFSR:STAIP,"192.168.1.33"
+CIFSR:STAMAC,"60:01:94:10:3c:32"
As the length of the IP address could vary considerably, because leading zeros aren’t used, the results need to be parsed. I knocked-up this (not very elegant) function to do that…
void Parse_AT_Data()
/* The function call wifi.getLocalIP() returns a string which contains
* the IP address and MAC address in this format:
* +CIFSR:STAIP,"192.168.1.33"
* +CIFSR:STAMAC,"60:01:94:10:3c:32"
* This function extracts the IP and MAC addresses as strings and assignes them to
* globally assigned String variables called IP and MAC
String AT_Data = wifi.getLocalIP();
int firstQuote = AT_Data.indexOf('"')+1;
int secondQuote = AT_Data.indexOf('"',firstQuote+1);
IP = AT_Data.substring(firstQuote, secondQuote);
int thirdQuote = secondQuote+18;
int fourthQuote = thirdQuote+17;
MAC = AT_Data.substring(thirdQuote, fourthQuote);
As you’ll see, it needs global variables declaring to hold the IP address and MAC address (I threw the MAC address in there for completeness while I was at it).
They go near the top of your your code (before void setup) so that they are global and can be accessed at any point:
String IP; // Global variable to hold the device IP address, assigned by DHCP
String MAC; // Global variable to hold the device MAC address
The full version of the Blynk Blink sketch with this incorporated looks like this:
http://twitter.com/blynk_app
WARNING!
It's very tricky to get it working. Please read this article:
http://help.blynk.cc/hardware-and-libraries/arduino/esp8266-with-at-firmware
You’ll need:
- Blynk App (download from AppStore or Google Play)
- Arduino Mega 2560 board
example.
#include <ESP8266_Lib.h>
char auth[] = "****"; // Test_Environment
char ssid[] = "****";
char pass[] = "****";
#define EspSerial Serial1
//#include <SoftwareSerial.h>
// Your ESP8266 baud rate:
#define ESP8266_BAUD 115200
// Set ESP8266 baud rate
//Blynk.begin(auth, wifi, ssid, pass, "blynk-cloud.com", 80);
//Blynk.begin(auth, wifi, ssid, pass, AT_Dataess(192,168,1,100), 8080);
Parse_AT_Data();
Serial.println();
Serial.print("Local IP address = ");
Serial.println(IP);
Serial.print("MAC address = ");
Serial.println(MAC);
// to avoid delay() function!
This produces an output like this:
[9]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v0.6.1 on Arduino Mega
[599] Connecting to UltraNet
[3648] AT version:1.1.0.0(May 11 2016 18:09:56)
SDK version:1.5.4(baaeaebb)
Ai-Thinker Technology Co. Ltd.
Jun 13 2016 11:29:20
OK
[4732] Failed to enable MUX
[7757] +CIFSR:STAIP,"192.168.1.33"
[7764] Connected to WiFi
[17971] Ready (ping: 11ms).
Local IP address = 192.168.1.33
MAC address = 60:01:94:10:3c:32
and as I said earlier, those IP and MAC values that are outputted to the serial monitor are available as global variables.
You’ll notice that my ESP-01 is running an old version of the AT firmware. I guess it’s possible that later versions produce a different format of output for IP and MAC address. If so then it should be fairly easy to tweak the code to continue working, but give it a try and see if it works.
I’m off for a lie down to recover from the emotional trauma of working with the Arduino/ESP-01 combination
